GMOS-LAN-012
I am wondering if this might be an updated version. It says it will work for both amplified and non-amplified systems, and does not give the caveat under the 09 Vibe of, "for Onstar retention only" that the Lan-01 and lan-02 says. Maybe most things will work better with this one.
An interesting thing is that Metra recognizes this one for the 09 Vibe (amplified and non-amplified), but it does not recommend this or any other interface (except the 70-2105 harness) for the 2010 Vibe in their vehicle fitment guide.
Crutchfield seems to be lagging on their fitment guide too if this is the right one.
GMOS-LAN-012
http://www.crutchfield.com/S-7kvLRIBFqG ... apter.html" onclick="window.open(this.href);return false;
http://metraonline.com/part/GMOS-LAN-012" onclick="window.open(this.href);return false;
http://a248.e.akamai.net/pix.crutchfiel ... MOSL12.PDF" onclick="window.open(this.href);return false;: Installation manual linked from Crutchfield
Axxess catalog:
GMOS-LAN-012 GMOS Interface
The GMOS-LAN-012 is designed to retain OnStar, OE satellite, and
retain the warning chimes that are normally lost when the OEM radio
is removed. Provides a 12-volt accessory output for aftermarket radio
operation. The GMOS-LAN-012 also provides a mute, parking brake,
VSS or speed sense, a reverse output, and an ASWC harness to
make installing an aftermarket navigation radio simple and less time
consuming.
From web pdf manual:
consuming.
It would be nice if there was no need to move pins and wires as some has had to do in other threads. Would also be neat to be able to use oem XM.
Somebody might have to call them.
2010 Vibe 1.8 auto, fwd, base, air, preferred package, cargo mgt, cargo cover, ultra white.
