Same here with both our Vibes. I'm not sure about my mom, but personally I try to use the steering wheel controls whenever possible.star_deceiver wrote:It hasn't happened to me yet.... Knock on wood!!!
You got it right! Knobs are the same AFAIK, so I expect them to break often. But even if I have to replace it once a year or two, it is still cheaper than a new radio or paying someone to replace it.Caretaker wrote:hmmm, still trying to capture this in my brain.
1. Are you saying that the new knob is different that the old knob or the same? I'm betting it is the same.
2. The knob breaks because the plastic goo encapsilating the metal clip breaks off of the clip causing the knob to spin. I think I have that right.
So, since the metal clip holds the knob on to the shaft inside the radio, you are saying that glueing is not necessary since the metal clip already comes attached to the new plastic knob. All I need to do is yank the metal clip off of the metal shaft inside, thus allowing the new one to slide onto the metal shaft. If I have that right, it sounds pretty easy, actually. How am I doing now?
I will only add, (because this happened to my radio during my first year more then three years ago) , DO NOT PUSH ON and PUSH OFF anymore. just turn the volume down. That will minimize the stress forces on the plastic knob. (both knobs)Caretaker wrote:Brilliant trb, thanks so much. With only 2 hours to go till I leave for the dealer, these two pictures are worth a thousand words. I'm not sure if a dealership will want to perform the frontal assault since it is not a "sanctioned" repair method. If they want to give me a new radio for free, so be it. If they even speak of charging me for a removal and repair or a new radio, I walk out knowing I can do this myself thanks to you.
And many thanks to vit, lowincash, trask and diluth for being brave enough to attempt it yourself and help me as well. I hope I didn't forget anyone in my acceptance speech....................oh, and my parents, my cats, my stage crew, my fourth grade teacher
There is no way to get to the inside of the knob to glue it except by removing the radio and taking the whole front off of it. If you are going that far, I would just spend the $7 - $8 for a new knob. The only other way is to destroy the knob like I did in the other thread posted above and cut the new knob flange off so it will fit without taking the radio apart.09vGT wrote:Question: Could you just glue it up or something and make it work? IF that is possible, I might try this. IF not, then I'll just use the arrows to skip around channels if need be
