J_TO_ENVY wrote:The Matrix OEM rack most definitely looks a lot better then the Vibe OEM rack!
Since the Matrix racks are going new on ebay for about $250, I would think $150-175 for a used one would be fair. Especially if it is missing the torque wrench!alex_nrv wrote: >> So, these oem racks are really selling for 500$ +++ at the GM dealer??? I'll be buying TOYOTA MATRIX 09 used. What prices should I expect for a used rack if I don't want to be ripped off?
Sure, just get them tight enough so they don't come loose, but not so tight you have trouble removing the bolts. Maybe SnowFish can let us know the torque specs so you have an idea.>> Also, if I don't have any torque wrench of any kind, can it be installed anyways without any problems?
Thanks a looooot !!
The installation seems to be pretty straightforward, relatively fast and easy. Probably as fast as installing the Thule on my GF's Mazda (which is easy and fast).trb wrote:Since the Matrix racks are going new on ebay for about $250, I would think $150-175 for a used one would be fair. Especially if it is missing the torque wrench!alex_nrv wrote: >> So, these oem racks are really selling for 500$ +++ at the GM dealer??? I'll be buying TOYOTA MATRIX 09 used. What prices should I expect for a used rack if I don't want to be ripped off?
Thanks a looooot !!
I have NO clue what 24 ftlbs is... I have no tools of any kind for measuring the torque, so even by "feeling", I don't get what this measurement is. I always tighten by hand... I tighten until there is resistance, then I give it a little extra "nudge". I will also be putting some LocTite to be sure it will stay well tighten.Since the rack will be second hand, chances are there won't have much LocTite still in the threads of the bolts.SnowFish wrote:Careful mounting the top rails. 32.0 Nm isn't that much. That translates to 23.6ftlbs. I went 24ftlbs. Doesn't take much to make it "click". Strip 'em and it will be a major "oh crap" moment.
Cross Rails, the allen wrench ones, are 9Nm, which is 6.6ftlbs, or 79.2 inch lbs.
We're not torquing down a head, but I still like to bring it up to spec gradually. My early observations is that you will not be disappointed with the Matrix rack.
Thanks, that's great guidelines for my upcoming installation!SnowFish wrote:There's nice rubber rail pads that come with the rack. No scratching.
If you're going to wrench, you need a torque wrench. Actually two. Foot Pounds & Inch Pounds.
Even these low end ones will take a ton of guess work out.
http://www.harborfreight.com/catalogsea ... que+wrench
Less than $50 for the two (1/2" ftlbs & 1/4" inch lbs). Can't afford not to have them.
You'll be amazed at how little, the torque spec is, on a lot of these fasteners. And yes, LocTite is your friend. The Blue Removable works for most applications.
alex_nrv wrote:It's done!
Bought the MATRIX 2009 bar kit for 120$ second hand.
What's funny, the night I fell on the ad for the rack, I didn't knew the true value of this rack, and I tried to bargain for 100$... but the price was firm, non negociable. Then, when I came here, I learned the retail price is 250$... and over 500$ for the GM oem rack... So I told the seller to keep it for me, that I would take it without an hesitation if there was nothing missing and everything was in good shape. So I got the rack half price, used but in really good shape.tpollauf wrote:alex_nrv wrote:It's done!
You got a STEAL of a dealI hope if I ever need one that I too will find a deal as you did. That truly looks classy on the 09-10 Vibe and appears to be functional also. Enjoy
