To me that place sounds like they may be just fishing for work. Did you have them look at the system? Are you having any problems with the AC? Did they hook up true manifold gauges or just a single gauge? True pressures should be measured while the system is running, and you should see a low pressure on the low side, like 30-50 or so, and higher on the high side, 150-200 or so. I would take it someplace else and have it checked if you are concerned about it.What static pressure should I expect to see when I hook up my gauge set.
Each refrigerant has it's own static pressure at every corresponding degree in temperature. The important thing to keep in mind is static pressure changes based on temperature. Any change of temperature brings with it a change of pressure. The greater the temperature, the greater the pressure. You can use a refrigerant pressure chart to find static pressures at various temperatures. Static pressure will not be used to determine if a system is fully charged. Using the chart below, if the R-134a system has a static pressure of 88 psi at 80 degrees F., we can then assume the system has some amount of liquid refrigerant. The system may be full -or - may not be. At the same temperature, if the system showed only 75 psi, we could say with confidence, the system is low. This is because static pressures shown on a temperature chart would show inadequate pressure for the presence of any liquid refrigerant.
I thought the place was a little shady to begin with so no, I did not have them look at the system. I have no issues with the ac. It looked to me to be a single gauge on the passenger side of the car but the hood was up so I couldn't see much, or specifically where, it was. I was thinking of checking and repairing myself. I've done the intake manifold gasket, alternator, cleaned the throttle body, maf sensor, rotors, and pads, so I feel very comfortable working around a car. Is there a way I can make checks and determine what to do from there. If so, please link me to a how to for this stuff. Thanks for such a quick repsonse. I appreciate it!trb wrote:From this website: http://www.aircondition.com/tech/questions/82/
