Hello everyone! I've been meaning to post a thread in here for a long time but I just got a new chord for my camera so I can upload pictures..So, meet "The Bug", which is a nickname my gf gave to it and it just kinda stuck.2009 Vibe Carbon-Gray AWD just under 60k milesUnder the hood all stock 2.4L 4-cylinder Toyota 2AZ-FE 2362cc engineThe Good-All around a very reliable, solid, and safe car-AWD with Stabilitrak, which is super awesome in the snow-All standard maintenance projects fairly easy for a do-it-yourselfer-2AZ-FE engine has some customizable/racing parts available since they're used in Scions-I got a really good freaking deal on it. (Purchased in 2009 w/ 4k miles on it for about $16k)-It's good for everything I need and want in a car, since I can't afford a Subaru Impreza WRX STI wagon and this gets better gas mileage anyways-My favorite thing of all:A place right under the hood to keep all my tools and loose nuts and bolts while doing work on it! SO AWESOME!!!!!!!!!!!!!The Bad-Couple of dings in front passenger door, slight dent in front driver side fender, as well as a scratch on the rear driver side fender from a hit n' run -Needs front driver side brake caliper replaced(I have no idea what the previous owner did to this thing in 4,000 miles), as I have to every six months or so take the lower caliper pin out and re-grease it.-***EDIT: Turns out that I am a moron. I read my owner's manual and the AWD actually IS full-time. The dealership misinformed me on how it works....I think.-I can't move my seat back far enough. This is not a super-long-legged person's car, but I've learned to get comfortable with it.-It vibrates(ha-ha). It's really annoying and apparently it's a motor mount issue I'm hoping is still under warranty.-Not a fan of the 4-speed transmission. I'd like a 5-speed auto-stick.-Oil drain plug replaced by a ****ty Everlast drain plug. Thanks, JiffyLube! You lying wreck-tech *******s.-Oil pan gasket is leaking -Most all of the miles on this car are from pizza/sandwich delivery jobs. But hey! It's still going strong!-Daytime running lights. Won't turn off. Ever. Why even bother having a knob to control it? ****ing stupid as hell.-Pontiac is retarded and has some wrong information in the Owner's Manual, for example listing the transmission fluid as T-IV when it is ACTUALLY Toyota WS.So Far-Had the rear main axle seal replaced, as it was leaking rear differential fluid(again I have NO idea what the previous owner did to this thing in 4,000 miles!)-Installed K&N air filter-Replaced spark plugs at 50k miles-Using Mobil 1 75w90 diff fluid in the rear differential and transfer case-Did transmission service early on, since pizza delivery was really tearing up the fluid. Used one of those risky "universal" synthetic fluids, to much success. It has been running just fine with no signs of internal wear. (Wolfshead Universal Synthetic ATF
http://www.wolfshead.com/)Coming Up-In a few weeks I will be replacing the leaky oil pan gasket, and while I'm at it I will be replacing the transmission filter for the 60k service schedule. I did the trans not too long ago but I want to be sure the filter is going to last until 120k miles. I plan on making a YouTube video of the project, as well as a thread!-Taking it to the dealership to have this vibration issue investigated...In The FutureI want to do all kinds of stuff to this car, from pointless to fun and everything in between. If anyone has any advice or resources for any of this stuff, pass it along! I won't be doing any of this stuff for a while (probably when the warranty is up) so the more I know the better.-install sway bar-install strut brace-Amsoil everything-custom roof racks-get nice rims-get snow tires to put on stock rims-get a better transmission-replace brake calipers-raise it an inch or two-fix dings-paint it black-"fix" the daytime running light problem -MAKE CAR GO FAST Haha pretty much I mean deck out the engine with performance parts. Starting with CAI or something, as well as improved exhaust.-(edited out due to stupidity)That's all I can think to share for right now! Bye!
