2009 - Looking for Dome Light pos+ wire
09Vibe
Post by 09Vibe »
Can someone point me in the right direction? I'm just looking to add a couple of strips of LED lighting to either side of the front floor area under the dash, every car I've ever owned has had floor illumination, kind of miss it when I drop something at night ! Just don't know where to tap into ... anyone done something similar ? Thanks ....
2009 2.4 Litre 5 Speed
joshuaeb09
Re: 2009 - Looking for Dome Light pos+ wire (09Vibe)
Post by joshuaeb09 »
As most domelights are - switched I just wired mine to a switch next to the traction control switch. If you really want to you could use a relay, If you look for an alarm installation sheet you should be able to find the - trigger for the domes.
2009 Silver Vibe GT AutomaticI/H/E/Unichip @ 93octaneMy Garage : http://forums.genvibe.com/zerothread?id=43521" onclick="window.open(this.href);return false; - Gone (Sold)
2005 Expedition Limited 2WD|4R75W 4SPD Auto|3.73 Gears|I/E|5Star Tuned@ 91|3" Lift/Level - Current Ride
Wish I could help you out right now BUT I will be doing similar LED modding to my Vibe GT over the winter. Hope someone else guides you in the right direction in the meantime
