Folks,i have 09 vibe with basic factory stereo. i am thinking to replace my factory stereo. I dont care about onstar anymore. Can some one please advise me by replacing factory HU what features i will lose on car? my local intaller is telling me i will lose more features of car.Here is the list i came across from metra site99-8224 Trim Kit70-2105 Harness (if i dont care of onstar)40-CR10 Antenna adapter Please advise me should i use basic harness will it fit good or i am stuck to buy metra GMOS-100 ?if some one have done project any help is greatly appreciated.UpdateMystery solved. I installed my stereo and its working 100% fine without any issue. again Dollar store gadget did the job to identify the wires i was looking for.DIY to follow next week.Cost of complete project In Canada:JVC KD-R810 $160GM2105 (Wrong Harness, Yes i used it) $ 18Antenna adapter $ 10American International Trim Kit TOY-K987 $ 20Total Cost $ 208Quality of Sound on Factory speaker 7/10Hours to Installwithout DIY guide : Two weeksAfter i Put DIY Guide: Two HoursSkills RequiredSoldering, Heat shrinking or Applying electrical tapeTools RequiredPrecision screw driver (Because there is no correct harness in market i found)Regular screw driver10mm SocketExtension bar for socketCons:NO ONSTARPros:Every thing works except Onstar (want onstar buy $ 100-200 harness, i am cheap i dont wanna pay that)No Check engine light or any thing.Driving listening every thing.
Since our cars are not truly GM cars, the onstar is an add on, and not integrated into the headunit. We also don't have retained accessory power. I think those are the only reasons for the factory integration adapters. As long as you can get the proper harness, you should be good. If you have steering wheel controls and want to keep them, you'll need something for that. There are a few different adapters out there, but I don't know which one would work.
i have two choice on harness here.one is Metra p/n 70-2105 and other is American International p/n TWH-950as per installer its same as toyota and even AI catalog for 2010 calls same number under 2009 Vibe.
ok finally i open trim and remove factory stereo to see the connector at the back. Surprise surprise "factory stereo has decal "Toyota" Made in Mexico and Harness connecting factory stereo was two connector not single connector. means i have to use Toyota connector TWH-950. i am going to do post DIY later on for this project. i am going to put my Avionics engineer's Hat on and make DIY for all of us.
Thanks for posting the part numbers. I'm using the Metra gmos-lan-02 right now, but Onstar isn't important to me, either. I'd like to ditch it in favor of something simpler. I really only need something to get accessory power because my headunit's power and ground are run straight to the battery.
