Stant InStant Gas Fill Cap
ou.grizzly
Post by ou.grizzly »
Have anyone ever tried one of these? http://stant.com/brochure.cfm?...pular
Re: Stant InStant Gas Fill Cap (ou.grizzly)
Nope, and I won't be the guinea pig! I can just see that thing getting covered in dust and dirt, easy way to get crud in the tank!
ou.grizzly
Re: Stant InStant Gas Fill Cap (star_deceiver)
Quote, originally posted by star_deceiver »Nope, and I won't be the guinea pig! I can just see that thing getting covered in dust and dirt, easy way to get crud in the tank!What is interesting Ford has this design on some of their newer vehicles.
Old Tele man
Post by Old Tele man »
...looks "environmentally" (hydrocarbon vapors) friendly!
...and the Devil said: "...yes, but it's a DRY heat!"
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
kcorona
Post by kcorona »
I tried one on a Saab and it didn't work because the cap kept the nozzle from opening the flap in the filler neck -- in other words too much space between the filler neck flap and where the cap screws on -- gas got everywhere.
'04 Shadow Monotone Base AT power pkg., + FIAMM low note horn, GM exhaust tip, GM splash guards x 4
keithvibe
Post by keithvibe »
I have a feeling you will get a CEL with it. people with loose gas caps get them.. just think what this one will do with a hole in the middle of it
midnighthunder89
Post by midnighthunder89 »
Funny you post this one of my design classes our team has to design a new gas cap, that is kind of what I was thinking, a check valve type thing. I really don't think it is a big deal to take off the gas cap but my prof thinks otherwise
2010 Vibe 2.4L 5 speed manual.
Whelan
Re: (midnighthunder89)
Post by Whelan »
Except Ford's design is a little more involved than simply replacing the gas cap with a filler hole and plunger. I could foresee this having issues with cars and error lights on the dash for not enough of a seal.Besides it states:"Race fans: Fill up like NASCAR does during a pit stop. "I'll pass
2012 GLI Autobahn 6MT
JetBlack09VibeGT
Re: Stant InStant Gas Fill Cap (kcorona)
Post by JetBlack09VibeGT »
Quote, originally posted by kcorona » the cap kept the nozzle from opening the flap in the filler neck -- in other words too much space between the filler neck flap and where the cap screws onI can see where this would be the problem and not the CE light. One would assume that this cap creates the proper seal. Your Check Engine Light typically comes on 99% of the time when something is not right with your vehicles emissions like a MAF, O2 sensor, or because their is an air leak in your gas tank and you are emitting Hydrocarbons. Otherwise its an interesting concept. I would prefer it simply because the lip on the fuel door doesn't properly hold the cap and then the cap ends up banging on the side of the car and scratching it.
jake75
Re: Stant InStant Gas Fill Cap (JetBlack09VibeGT)
Post by jake75 »
I would not want one because I need the exercise.
