* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
i've used plastx on my headlights and it did work with making them clearer It also works on the interior gauges. Quite a few members have had good success with this stuff.I've never used the turtlewax stuff but if your lights are really bad, it might be cheaper to buy that kit instead of buying the meguirs and paper seperately.and fyi -- whelan posted a how-to:http://forums.genvibe.com/zerothread?id=32206
I used the 3M kit recently on some really bad Grand Caravan headlights and had great results. The 3M kit can be had for about $18 at WallyWorld; it comes with 3 types of buffing pads, a foam polishing pad and polish. After completing the lights on the ManVan, I had enough material (pads and polish) to do the lights on my Ranger...and those turned out great too. In fact, the 3M kit includes so much polish that I'm just going to polish them out w/the foam pad every Spring from now on. One thing to note: Some of these headlight kits come with a final-step sealer...the 3M does not. However, I would think any decent nanowax spray applied periodically (I nanowax my cars twice a month) would be fine.
Quote, originally posted by bull77 »i've used plastx on my headlights and it did work with making them clearer It also works on the interior gauges. Quite a few members have had good success with this stuff.I've used the plastx on my interior and on my headlights and it worked wonderful. But like bull said, if your lights are really bad, the turtlewax might be cheaper than buying the plastx and paper separately.
Quote, originally posted by specialbuddy »Is it easy to clean the inside of the headlights. My lights look dirty on the inside.unless you think baking open your headlight easy then sure yea it's easy.
Quote, originally posted by specialbuddy »Is it easy to clean the inside of the headlights. My lights look dirty on the inside.is it dusty? try pulling the bulb and use a can of compressed air gotta try plastix or plexus or the turtlewax kit soon too... 2 years after my accident, i'm noticing the replacement lense is a tad clearer than the original on the other side.
de-badged o4 vibe
o2 triumph speed four
Forget the kits. Get yourself some wet sanding paper. Get really smooth grit like 2000, 2500 and 3000. Then start with the rough, work to the light. Once done, you can use the PlastX to buff with a machine. The results are amazing. Just go onto Meguair's forums and see results.
