PlastX takes several coats to clean up. Did you do it by hand or machine. With a machine it comes out better and cleaner.If it is scuffed and not hazed then you may have to go to wet sanding. Something like a 2000 grit on the lamp, then to the lighter stuff. Clean then reapply the PlastX. It is made to get rid of very light hazing, so if you have scrapes that your fingernail could get caught in, the PlastX is not a filler and will not clear that up. You need to get it to a very fine haze first.
http://www.meguiarsonline.com and check out the forum on clear plastic detailing.
