I keep seeing the term "de-badged" used when people describe their Vibe. How do you remove the badge with no paint damage. I would to be rid of the "Pontiac", "Vibe" and "GT" badge from my 2009. Thanks for any info.
fishing line and goo-gone ... easy peasy... unless they are pinned on the new 09'sPinned='s small pin extending from the badge threw the sheetmetal. If you were to take those off there would be a hole left in the car
I can't say about cars but on motorcycles, heat is applied with a heat gun then fishing line is worked between the badge and the paint. Use the fishing line like a saw moving the line back and forth. Once the badge is off, use a cleaning product to remove any residue.
Quote, originally posted by Colorado Vibes »I can't say about cars but on motorcycles, heat is applied with a heat gun then fishing line is worked between the badge and the paint. Use the fishing line like a saw moving the line back and forth. Once the badge is off, use a cleaning product to remove any residue.i did the sae thing, except used a hair dryer to heat the badge, then the g-string which was previously broken on my guitar.yeah go ahead. let the g-string jokes begin.
de-badged o4 vibe
o2 triumph speed four
usually you heat the badge with a blow dryer then use fishing line or floss to get it off. then use goo gone or bug remover to get the sticky crap off then you have to wax that part of the car reeeeaaaalll good.
no need for heat gun...on my old car i left it outside in the sun and during my lunch break at about 90degrees i just used my pocket knife and pry the badges off...took about 5 minutes for the letters and another 10-15 minutes for the left over glue...got a nice sunburn too
Quote, originally posted by NibCrom »Don't be ashamed of what you drive. +1Quote, originally posted by ramenboy... »i did the sae thing, except used a hair dryer to heat the badge, then the g-string which was previously broken on my guitar.yeah go ahead. let the g-string jokes begin.HAHAHAAA!!
I'll probably debadge my 07 Vibe soon. I'm not ashamed of what I drive. It's just a pain to get the wax off around the badges. I'm also a little annoyed with the pink arrowhead on the back. I wonder how long it would have taken me to notice that if I wasn'y a member of this forum ....I intend to park the car in the sun & use dental floss or fishing line.
