2004 Vibe GT Intake Installed
Bocaj77
Post by Bocaj77 »
I installed a intake today on my 04 Vibe GT it was the CAI off of my 03 GT. I cut it down and had to make it a short ram. My question is there is a vacuum line that runs from the intake under the intake manifold over to the passengers side of the engine. This was not on the 03 Vibe GT. For now I just left the vaccum line open and tucked it up. What have others done with this vacuum line??
Ninja_Logan
Re: 2004 Vibe GT Intake Installed (Bocaj77)
Post by Ninja_Logan »
i just left it and i got a CEL, so i reset my ECU and plugged it hoping it would solve the issue but it came back again. So im takin mine to get the codes pulled asap. but if you get a CEL take it in to get the codes pulled asap. otherwise your golden!
ajflan
Post by ajflan »
Do you have any pics of the aforementioned line?
February 08' VOTM Check out my Band! http://www.facebook.com/pages/...67945
Bocaj77
Re: 2004 Vibe GT Intake Installed (Ninja_Logan)
Post by Bocaj77 »
I read the code it was a lean code. And its a small vacuum line that runs under the intake manifold from the stock air box.
Petrucci914
Post by Petrucci914 »
I thought the 04 GT had an air pump, so it had an extra part needed to hook to the intake. So you need to buy one for your year.
2003 Pontiac Vibe Base - AutomaticTRD Supercharger w/ Smoothflow PulleyaFe Drop-in Filter - DC Sports HeaderFull 2.25" Exhaust -Magnaflow Catback + CatsOptima RedTop - Tru-Cool Tranny Cooler
vibegtcouple
Re: 2004 Vibe GT Intake Installed (Petrucci914)
Post by vibegtcouple »
on my i but the cai on i but a dent right at the point were the air pump would hit it fits good . the hose is for your egr i think. you car go to az and get a vac . print out to see what it go to .
vibegtcouple
Re: 2004 Vibe GT Intake Installed (vibegtcouple)
herhttp://forums.genvibe.com/zerofile/10726/CIMG2069.JPGe is where the fliter came out
Bocaj77
Post by Bocaj77 »
I figured it out, you take that vacuum line and attach it to the nipple under the throttle body.
