Too Hot!
KSNeptune
Too Hot!
Post by KSNeptune »
After a week or more of 100+ temperatures, with some higher than 110f, I think my Vibe's dash thermometer has bitten the dust. Took it out today from my Air conditioned 80 degree garage, and it never changed from 81 degrees. Parked the car in the sun for a half hour or so, with the temp at 103, and even though the interior was almost too hot to touch, the thing still only read 81. Previous to today, the thermometer would accurately match local bank signs showing the 105, 109, 113, or whatever scorching temperature it really was.So this may be one for the dealership. Anyone else have a flawed thermometer?KSNeptune
millster
Re: Too Hot! (KSNeptune)
Post by millster »
Interesting. We've had plenty of scorchers here too and so far the only strange operation I've had is when I go to the car wash and the car displays about 30 degrees lower than the actual temp. I'd say that's definitely one for the dealership. I just wish it were that simple to fix these horrible temperatures!
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
disneydj
Re: Too Hot! (millster)
Post by disneydj »
It won't display anything if it's dead. Just two dashes... take it in and have them look at it. We're in the 100's here all the time in sunny Florida, and I only had a problem with mine after my run in with that Dodge Ram months ago. Good luck!
pmh013
Re: Too Hot! (disneydj)
Post by pmh013 »
I've maxed out the lower range before, but never the upper range. Hottest I've seen is 38°C (100.4°F), which is still in the range of the temperature sensor.More discussion on the range of the sensor can be found here: http://forums.genvibe.com/zerothread?id=2231&page=1 , and here http://forums.genvibe.com/zerothread?id=783.
2003 Satellite AWD Two Tone, traded off at 180,126 kmNow the (fourth) catalytic converter is someone else's problem Now driving a 2007 Dodge Grand Caravan
Sputnik
Re: Too Hot! (pmh013)
Post by Sputnik »
Yeah I've maxed out the lower range as well, but it never got stuck there.
GenVibe Global Moderator
Current: 2012 Nissan Juke SL - Sapphire Blue Onyx (July '12 - present)
Current: 2012 Nissan Leaf SL 100% Electric - Blue Ocean (Dec '11 - present)
Past: 2003 Pontiac Vibe - Satellite Silver (Aug '02 - Dec '07)
KSNeptune
Post by KSNeptune »
Rain and much lower temperatures lately. Temperature reading looks like it fixed itself. A shame, really, since I'll have no way of proving the flaw to the service technicians. Then again the error could have simply been due to the extremely high temperatures and hopefully won't return (either the high temps or the broken thermometer).KSNeptune
