For the Vibe it would be, in order from the engine to the filter, boot kit, 8738, 8738, 8705, 8707, 8698, 8718, 8728, filter.That is 45, 45, MAF sensor mount, manifold, 90, 6" straight, 22, filter.The boot kit number is 8771(blk), 8772(red), 8776(blue).On the second 45, I had to drill for the PCV hose kit adapterThat kit number is 8711The manifold piece has three plugs that can be used on other cars for small hose connections. I used none of these. It was the only piece that fit.Take out the batteryThe front bolt holding the fuse box has to be removed. Once you get it together and attched to the engine, replace the battery and secure it. You will see that the fuse box doesn't line up with the bolt hole. I used a heavy zip tie to secuer it and keep it from moving. I know an bracket can be made with this small offset, when I get it done I will place the plans for it on here. From underneath the car, remove the bolts holding the black splash trim and swing it out of the way. You can see the Tube sticking down behind the drivers headlight.If you choose you can put the filter on the 22 first and stick it up through while another person connects it to the 6" straight (before the battery is replaced).I was thinking about adding another piece so it hangs down a bit more in front of the radiator. That would be for a car show though, not daily driving. Th whole unit fit so snug
04 Vibe "SS" (Pontiac Dealer/Owner project),"SS"/TRD GraphicsTRD Tuned by Toyota (Dealership)Vibrant Strutbar,Polished Stainless Muffler Spectre Modular CAI- Body ColorBody Color Engine Cover w/Grafxwerks reflective overlayStellar Alarm System, Sony Xplod "GIGA PANEL" Blacked Out Z-24 15" rims w/ Goodyear Triple Tread Assurance
