Sold! on Friday July 11th, 2008 for a 2009 Jet Black Vibe GThttp://forums.genvibe.com/zerothread?id=33976Pre mod:+2006 Base+Moonstone exterior+Graphite interior+4-speed Auto+Sport Package+Prem. Monotone Appear PackageMods:+K&N Typhoon Air Intake (slight mod)+Added GM chicklets +Hella twin horns +Grilles painted black all 5 of them (chrome painted red) +Lots of GrafxWerks (more to come) +Spark plugs +Painted engine cover & fuse box+Throttle Body Coolant Bypass +Red calipers & drums +Silverstar headlights My Cardomain PageFuture mods:2009 Camaro, yellow w/ black stripesI want so badly:I got 15% all aroundThe Others:
“I live my life free of compromise, and step into the shadows without complaint or regret.â€
Viva la Pontiac! 2009 Jet Black GT
that does look awsome! and what color are you going to put on the arrow??? cause you can paint the crome part of the arrow that same color red as the trim around the grill.man i wish we (03-04 models) had that chrome thing now cause that is Sick!! now all you need are some GTi badges and you have a one off Vibe GTi very special editions aka 1 of a kind.
Quote, originally posted by Katscan »What color black is that? Glossy, Metalic? and what paint did you use? It looks sweet!Both paints were Krylon the red was X metals the black was fusion for plastic the color is 'gloss black', the stuff dries in 15 mins, the grilles were back on in an hour. It only needed two coats for the black, the red needed three.Quote, originally posted by NascarXprt »that does look awsome! and what color are you going to put on the arrow??? cause you can paint the crome part of the arrow that same color red as the trim around the grill. I got Grafxwerks decals, the inside is going to be reflective red (I wish after seeing the way the grille turned out that the arrow would be the dark red oh well) with a reflective black broader. I wanted to keep the arrow red.
If you notice the red part of the grille... you'll see the paint chiping off I'll try to patch it up, but most likely I'll repaint them with something different.
WHOA! dont wear flops... you might slice a toe off V!Cool looking though. nice mod
I'm not really a star trek fan but those look like something a klingon would have on his/her vehicle.those look scarry my toes want to remain hidden in the shoes around those pedals!! Looking good though!
Nice work, V! A lot easier to do than the cable throttle engines where those hoses are on the back side of the TB.Cold: It prevents the hot coolant from circulating through the TB. This will help to keep intkae temps down so your engine creates more power. Not much just a few HP. But you will notice the slight difference. The coolant running through the TB is mainly for cold climates, supposedly to prevent any frost from building up in the TB but I, and may others, have done it with nice results and not problems with frost in the winter, whatsoever!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
warm coolent is sent throught the throttle body so it won't ice up during the winter, but because I live in FL, it doesn't get that cold. the mod keeps the air from the CAI from warming up which = MORE POWER!!!!! Edit: what Blue said Thanks Blue
Quote, originally posted by K-NINE »Is this some kind of kit that you purchased? All you need is a connectorI'll find a pic of it, I'll get it up LATE tonight or tomorrow afternoon. this Mods is about $7. and it's easy.
U may want to get some type of plug to cover up the inlet and outlet ports on the TB so dirt and engine crud don't get in there. Otherwise, your well on your way to getting the car SC.. lol A little HP here and there will leave you only wanting more
Looks sweet V .I really like your pedals.The red on the grilles look great,really sets you apart from the rest.Keep up the good work.P.S-I would stick a hose on the empty ports,so no dirt get in the throttlebody though.
Quote, originally posted by kevera »P.S-I would stick a hose on the empty ports,so no dirt get in the throttlebody though.I don't know why I didn't think about that, thanks guys.
Quote, originally posted by keithvibe »U may want to get some type of plug to cover up the inlet and outlet ports on the TB so dirt and engine crud don't get in there. Otherwise, your well on your way to getting the car SC.. lol A little HP here and there will leave you only wanting more Quote, originally posted by kevera »P.S-I would stick a hose on the empty ports,so no dirt get in the throttlebody though.Actually, the ports don't need to be plugged, because they are just their own line and don't/won't mess with the TB, there is no where they can go to to get into the engine.
