A radding noice in my car
SuperSpeedWagon
Post by SuperSpeedWagon »
Just yesterday I was racing a car but thats besides the point I started hearing a wierd raddling noice next to my a/c vent on the passenger side and it got louder as my rpms got higher I took apart everything to see if anything was loose or could be loose, and put it all together. Well i went to a long stretch of road to see if it did it again and it did so Im stumped do you guys have any clue what it might be. your info would be greatly appreciated thanx
2010 vibe gt
josholiver1
Post by josholiver1 »
Mine does the exact same thing, it also does it when AC and fan is on HIGH..Have no clue what it is...
steveaux
Re: (josholiver1)
Post by steveaux »
Mine just started this today but it makes the noise with air off also, I see the pad above the cabing filter tapping (in rhythm with the blinking seat belt off light) so it appears to be electrical. Any suggestions out there?
steveaux
Re: (steveaux)
Post by steveaux »
I Played around a bit and if I turn on the recirc the tapping stops, and If I turn the air off and the recirc off thye tapping starts again. So for right now that is my only fix is to turn on recirc to stop the tapping, I hope someone out there has more
SuperSpeedWagon
Re: (steveaux)
Well mine is only at a high rpm or when I have the setting for my a/c at the 2nd circle so I'm going to have to gutt my car again to see whats up i'll keep you updated maybe I'll find out what the hell it is.
2010 vibe gt
Re: (steveaux)
Quote, originally posted by steveaux » I Played around a bit and if I turn on the recirc the tapping stops, and If I turn the air off and the recirc off thye tapping starts again. So for right now that is my only fix is to turn on recirc to stop the tapping, I hope someone out there has moreSounds like there are problems with the mechanism for the door that cuts off airflow for switching to and from recirculate mode....The motor/etc. have become stripped or otherwise damaged on a number of vehicles so far. Check here for starters...
northvibe
Post by northvibe »
There might be a TSB about a in dash rattle...My vibe was in for some pre 36k "noises" and "clunks" that i "heard" but i told them my A-Pillar rattled...but they fixed a in dash rattle...yea they didnt fix the A-pillar. but if you have warranty they prolly have a tsb about that..
steveaux
Re: (ColonelPanic)
Post by steveaux »
I think that may be it, while driving there was a few second delay when I turned off the recirc, so I looked while not driving and there it was, as soon as the door moves in place to take outside air it starts clicking. It does move the panel all he way over but it appears it wants to keep on moving, and hence, the rapping, tapping sound, evermore.I surprised it is stripped as I always leave the recirc off so the motor has barely been used. I wish it could be a simple adjustment.
jjhendri
Re: (steveaux) Ratting from a/c unit inside car
Post by jjhendri »
Well I got the same problem live in FL and yesterday it started (09/13/06). I always keep mind on recir and got louder as speed increased. Took off of recir and the noise disappear. I'm out of warranty ('03 GT with 73,400 miles). Any clues of how much it cost to fix?
Baltovibe
Re: (steveaux) Ratting from a/c unit inside car (jjhendri)
Post by Baltovibe »
Quote, originally posted by jjhendri »I always keep mind on recir and got louder as speed increased. Took off of recir and the noise disappear. Any clues of how much it cost to fix?There is a thread on the problem and the cost of replacement.http://forums.genvibe.com/zerothread?id=23946
NascarXprt
Re: (SuperSpeedWagon)
Post by NascarXprt »
i have a rattle to and not sure where its coming from its bad in the high rpms and bad at stop lights and a/c is on and off and it still does it. so im stumpd....
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
