How To: Disable the Seatbelt Beep - '05 - '08 only!
BlueCrush
Post by BlueCrush »
THIS IS FOR '05-'08 VIBES ONLY. SORRY '03-'04 & '09+ I found this on MatrixOwners.com (originally from Toyota Nation and the Prius). It's very simple and it works.This will turn off the 1 minute beep if the car is running and either the passenger or the driver takes off their seat belt.Get in the car and turn the key to on (don't start the car,) then change the odometer to display "odo" and not trip A or B.Turn the key off.Turn the key back to on. Within six seconds of doing this, press and hold the odometer button. Do so for 10 seconds. Then, while still holding the button, buckle up, edit: then unbuckle. The "odo" display should then change to say "b-on." let go of the odo button to get it to read "b-off." Then wait for the display to change back to the odometer. That's it, you're done.The car will still beep right when you turn it on for 3 seconds if you don't have a seatbelt, but the dash light will continue flashing till buckled up. It won't beep if you or your passenger unbuckles for a moment. Salvation!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Re: How To: Disable the Seatbelt Beep - '05 and up only! (BlueCrush)
I request this be sticky-fied! Good info.
GMJAP
Post by GMJAP »
Awesome post! Great info!
djpositivek
Post by djpositivek »
Wow this is sweet. I was expecting to have to go cut some wires or something... Even I can do this one !Not really a big issue for me cause we always wear our seatbelts but I think I'll do it anyway. Thanks for the informative post.
Abyss 2005 FWD 5 speedDe-badged
Toasted7
Post by Toasted7 »
I'm going to have to try this for sure and see if it fixes my issues with the "beep".
VMFIC of Cincinnati Scikotics Cincinnati Scikotics sponsored by: KerryScion.com My other ride is your mom
navydave
Post by navydave »
Just did it to my 05. No more annoying dinging! :-)
djpositivek
Re: How To: Disable the Seatbelt Beep - '05 and up only! (navydave)
ok I finally got around to doing this... Worked like a charm. Too lazy to print the instructions off and my memory sucks so I brought the laptop out to the car will come in handy every now and then. I wonder if there are any other little secrets like this one ?
2001FZ1
Re: How To: Disable the Seatbelt Beep - '05 and up only! (djpositivek)
Post by 2001FZ1 »
That annoying beep keeps my wife from getting those stupid seat belt tickets. It has probably saved us $300 by now.
Joe2005 Vibe GT2000 Silverado 4x41993 Camaro Z/28Riding a '05 GSXR-1000. ~ Full (removed). Akropovic exhaust, power commander, custom map = 166 horse My wife rides a crazy fast Ninja 250
binary
Re: How To: Disable the Seatbelt Beep - '05 and up only! (2001FZ1)
Post by binary »
Quote, originally posted by 2001FZ1 »That annoying beep keeps my wife from getting those stupid seat belt tickets. It has probably saved us $300 by now. And just think - it may save her life too! http://www.binaryspiral.com/20....html
rdavis85
Post by rdavis85 »
THANK YOU!!!!!
Pick
Post by Pick »
It's been said before and i'll say it again.THANK YOU
Eric05 Vibe
BlueCrush
Re: (Pick)
Post by BlueCrush »
You're Welcome! FYI: I have found that if you disconnect the battery you will have to disable the seatbelt beep again after reconnecting the battery.
My Fleet:
Pick
Post by Pick »
ah, more good info.
Eric05 Vibe
Jaxy
Post by Jaxy »
Can't wait to try this after work -- I have to take mine off to lean over and get the mail out of the box. It always seems stupid to have to put it back on to go down the (very long) driveway to the garage. THANKS!!
2005 Base Platinum, Tinted WindowsLeather Seats, Moon & Tunes, Power Pkgde-badged
mugsync
Post by mugsync »
I asked the guy at the dealership YESTERDAY to make the beeping stop! He said I had to live with it. I wear my seatbelts but my dog likes to ride in the front seat, then in the back seat, and then in the front seat. All that jumping around...all that beeping....uuuggghhhh. My long ride from NC to MS was very annoying. Of course, it never occurred to me to buckle the seatbelt. Thank you for this info. I am printing it off and taking it by the dealership today.
Jaxy
Re: How To: Disable the Seatbelt Beep - '05 and up only! (mugsync)
Post by Jaxy »
Hehehe - I had the same problem with my dogs. The really good thing is the passenger seat doesn't beep at all any more, not even for 5 seconds like the driver's seat...
Mario
Post by Mario »
"The "odo" display should then change to say 'b-on.'"I don't know if I'm the only one, but after holding down the odo button for 10 seconds I'm not getting any 'b-on' display. Any suggestions?
jeffgtx
Re: (Mario)
Post by jeffgtx »
good find. thanks
JeffGTX's Shades Of Gray Pontiac Armada:Cool: 2008 Solstice GXP ConvertibleSly: 2009 Solstice GXP CoupeMaverick: 2009 G8 GXP
jeffgtx
Post by jeffgtx »
worked for me 05 base... thanks!
jeffgtx
Re: (Mario)
Post by jeffgtx »
Quote, originally posted by Mario » "The "odo" display should then change to say 'b-on.'"I don't know if I'm the only one, but after holding down the odo button for 10 seconds I'm not getting any 'b-on' display. Any suggestions?you get the b-on when you insert the belt in teh buckle, which is after the ten seconds
Vangrest
Post by Vangrest »
I just have to say y'all have made my day!! This really works. I have a long driveway and have to get out to open/close a gate and get the mail so the constant beeping of the seat belt buzzer was really irritating me. Sweet!!
BlueCrush
Re: How To: Disable the Seatbelt Beep - '05 and up only! (Vangrest)
Post by BlueCrush »
Excellent and Welcome to GenVibe!
My Fleet:
isaaclud
Post by isaaclud »
nice.......it worked....I LOVE THIS SITE!makes me wonder how many OTHER aspectsof this car can be controlled by just changing software settings instead of hardware swapping (I.E. the sunroof half-stop thing)
PEACEISAAC
shanemade
Post by shanemade »
thanks BC worked like a charm. Great to have such an informitve site for our cars and the PEOPLE to go along with it.Cheers,Shaner
Shaner
umbriago
Post by umbriago »
I wouldn't have thought this possible so I didn't bother looking. That said THANKYOUTHANKYOU, this is Salvation, indeed.
GhettoBootyLover
Post by GhettoBootyLover »
WOW!!! Thanks for the great advice. I have to take my seatbelt off to get to the super low ATM machine and that "passenger ejection: thing might come in handy as well. Keep up the good work everyone. By the way, does anyone know how to make the cigarette lighter / data port continue to charge while the ignition is off?
"got booty?"
LUVROK
Post by LUVROK »
Didn't work w/ my 05GT?
2005 GT, Neptune, Injen CAI, Magnaflow Catback Exhaust, Eibach Sportline Springs, Progress Rear Swaybar, DC Sports Strut Tower Bar, Tow package
auntiedonna
Post by auntiedonna »
Wow thanks! My dogs always ride in back but the groceries and the laundry sometimes ride in the passenger seat, and they always forget to fasten the belt. I'll try it next time I get groceries.Donna
BlueCrush
Re: (LUVROK)
Post by BlueCrush »
Quote, originally posted by LUVROK »Didn't work w/ my 05GT?I wonder if it has something to do with your Vibe not having the power package or the fact that your's is a GT?
My Fleet:
BuzzDog
Post by BuzzDog »
THANK YOU, THANK YOU, THANK YOU for posting this!I tried it just for kicks this afternoon; then by coincidence I went to Home Depot and purchased 20 2x4s, for which I had to fold the passenger seat forward. Never had this happen before, but I kept noticing the seatbelt light above the radio was flashing. You guess it...the sensors must have "read" the lumber as a passenger. This tip kept me from having to listen to that constant "BEEP, BEEP, BEEP" on my drive home!
BuzzDogLocated in beautiful Northwest Arkansas2005 VibeFrosty • Moons and Tunes
KrazyB
Re: (jeffgtx)
Post by KrazyB »
Are you strapping up the drivers side? It has to be the drivers side not the passenger side. Try it out.
BuzzDog
Post by BuzzDog »
Yes, I always wear my seatbelt. Could it be that the lumber placed weight on the seat tracks?
frankandby
Re: How To: Disable the Seatbelt Beep - '05 and up only! (ColonelPanic)
Post by frankandby »
We have a 06 vibe and the second bell was so annoying. We were going to have to give up the vibe So thank you thank you thank you I love my vibe again. It was our second one. I am so happy
Luckylindy
Post by Luckylindy »
Good info. Wish it would completely disable it. Don't need an anoying beep to tell me to do something I do religously anyway. But it is a good start.
cmhj2000
Post by cmhj2000 »
OUTSTANDING POSTThanks for the info.
Viberrrr
Re: (cmhj2000)
Post by Viberrrr »
Very good info, I now wish I had a 05 just so I could play along. But the bigger question is: BC how did you figure this out? and why would one look to the odometer button to solve a seat belt issue?
BlueCrush
Re: (Viberrrr)
Post by BlueCrush »
The first post reveals all!
My Fleet:
WaveAction
Post by WaveAction »
shouldnt their just be a lil clip that u can undo under the seats? i know with most cars..well with my sunfire..it was just 2 wires being held on by a plastic clip which ran to the seat belt...not sure if it's the same for the vibes
Re: (WaveblueVibe)
I'm sure that is possible, there has to be wires somewhere that come from the buckle switch... But IMHO, that's a bad thing to do. The buckle switch is used for more than just turning on the buzzer to annoy people... The air bag controller also uses the input from the seat buckle to help it determine how the air bags should deploy - whether they go off with the first stage, second stage, or not at all... By disconnecting the seat belt buckle wiring, you're basically making the car think that the passenger is wearing ther seat belt at any time, whether they are or not, and that will affect air bag deployment. And can end up causing injury.
n2ho
Post by n2ho »
Works like a charm! Thanks for great post.GeorgeVibe 2007
Shadow Realm
Re: How To: Disable the Seatbelt Beep - '05 and up only! (n2ho)
Post by Shadow Realm »
Thanks for the great post. It took a couple of tries to get it to engage. I had to do the steps but wait about 15-20 secs then put seatbelt on to make it work. thanks againShadow Realm
Abyss Monotone GT, 6 speed, Moon & Tunes, Power Group,and 16" Alloys. Soon you can see my Vibe GT at Shadowrealm's car pics but for now it is under construction!
kurgen07
Post by kurgen07 »
This is great! thanks for the info, you have prevented alot of insanity.
jdood
Post by jdood »
Worked the first try on my 2006 ....many thanks!!
needles
Post by needles »
thanks for the great info. whoed a thunk it
[IMG][/IMG]
moongdss
Re:
Post by moongdss »
OP - (removed) YOU ARE A SAINT!! A few months ago, I picked up a bookcase and put it inside with the front seat down and that damned beep drove me BATTY!! I honestly think that's the only time I've gassed up while running so I wouldn't have to listen to that beep anymore on that ride.Folks I got this mod on the first try out in the parking lot after work, I was so excited to get this done. It's a no brainer!Question though, do you repeat this process to turn it back on? In case I ever want to sell the car, I'd like to put it back the (annoying) way it came so the next owner can join Genvibe for the solution
Pandora the 2006 Pontiac Salsa Vibe, 17"wheelsMods: tint, "Pandora" windshield decal, front badge skull overlay, rainguards, hoodguard, Projectorz headlite covers, black painted grills, FIAMM dual-tone horns, black grafxwerks overlays, redouts, Genvibe decals, splashguards, scangaugeII, 12v console outlet, DRL interrupt and I turned off that @#$% seat-belt beep! upcoming: red interior LEDs
Whelan
Re: Re: (moongdss)
Post by Whelan »
Yes, repeating the process will allow you to select b-on or b-off. For those of us who do work on our cars, anytime I disconnect the battery for whatever reason I have gotten this so embedded it's like second nature to clear up.
2012 GLI Autobahn 6MT
MRCN RCE
Post by MRCN RCE »
ha ha i freakin this site. i'm glad it's off. i buckle up anyway, but i don't wanna be stuck hearin that beep every time i have a passenger who doesn't wear a seatbelt.
GENVIBE: THE PLACE WHERE ALL THE COOL KIDS HANG OUT05 GTK&N SRI, exedy clutch, fidanza flywheel, Neo-GensLIFT: the equivalent of viagra for your tach n speedomy garagehttp://forums.genvibe.com/zerothread?id=24931
woodysmom
Post by woodysmom »
darn it didnt work for me..my vibe is an 05, not gt. why oh why...someone please help me. i tried several times and even waited for the 15-20sec but nothing happened after that.
GMJAP
Re: (woodysmom)
Post by GMJAP »
Quote, originally posted by woodysmom »darn it didnt work for me..my vibe is an 05, not gt. why oh why...someone please help me. i tried several times and even waited for the 15-20sec but nothing happened after that.Worked for my base 2005. Try this:Get in the car and turn the key to on (don't start the car,)change the odometer to display "odo" and not trip A or B.Turn the key off.Turn the key back to on.Within six seconds of doing this, press and hold the odometer button. Do so for 10 seconds.Then, while still holding the button, buckle upThe "odo" display should then change to say "b-on." let go of the odo button & press it to get it to read "b-off." That should be it.
murphsouth
Re: How To: Disable the Seatbelt Beep - '05 up, chime, alarm
Post by murphsouth »
Awesome!I love my Vibe but hated being told what to do by a machine. I buckle up when I get going and if I don't feel like it, locally, then I don't do that.This is a great solution to the most obnoxious chime and it's fairly easy to do (took 2 tries though???). I think you have to turn it to the RUN not the ACC position (both illuminate the LCD odometer display).
