My HID lights i just order 2 days ago. total 600 bucks, including install. the color i chose is blue
vibe2003
Post by vibe2003 »
cost me 600 bucks man.
damronjr
Re: My HID lights i just order 2 days ago. total 600 bucks, including install. (vibe2003)
Post by damronjr »
Looks great! I have eyeballing some purple ones on Ebay but wasn't sure of the quality enough to pay about the same price for heads and fogs.
vibe2003
Post by vibe2003 »
it's sooo bright lol.
damronjr
Re: (vibe2003)
Post by damronjr »
Quote, originally posted by vibe2003 »it's sooo bright lol.It was $600 just for the heads? I thought raging only paid $900 for heads and fogs and the ones I'm looking at on Ebay are $275 per set?
vibe2003
Re: (damronjr)
Post by vibe2003 »
the 2 set is 415, then i had to pay taxes and installations and that come up to 600 bucks!
damronjr
Re: (vibe2003)
Post by damronjr »
Quote, originally posted by vibe2003 »the 2 set is 415, then i had to pay taxes and installations and that come up to 600 bucks!Ah, I see! Where did you go to get them installed?
Smokin' Rubber
Re: (damronjr)
Post by Smokin' Rubber »
The only thing I'd be worried about is being ticketed by the jack@ss cops here for having xenon's otherwise I was contemplating getting them. Btw, what did they do with the daytime running lights? Just disable them?
vibe2003
Re: (Smokin' Rubber)
Post by vibe2003 »
lol. i have'nt got that figure out yet. any info on how i can turn the life time lights off? i hate it.
vibe2003
Re: (damronjr)
Post by vibe2003 »
my bodyshop(speedzone).
ragingfish
Post by ragingfish »
It's not an issue of disliking the DRLs. YOU NEED to disable them. The reduced voltage output of the DRL mode can fry your ballasts. You should do that sooner than later...if you didn't already fry them.
2009 PONTIAC G8
Smokin' Rubber
Re: (ragingfish)
Quote, originally posted by ragingfish »It's not an issue of disliking the DRLs. YOU NEED to disable them. The reduced voltage output of the DRL mode can fry your ballasts. You should do that sooner than later...if you didn't already fry them.I wish that you didn't have to disable them when you get HID's... When you disable the DRL's does it also kill the auto turn on for the head lights?
ragingfish
Quote, originally posted by Smokin’ Rubber »I wish that you didn't have to disable them when you get HID's... When you disable the DRL's does it also kill the auto turn on for the head lights?As of now, yes. No one has found a workaround that kills only DRL and not TS.I personally have become accustomed to driving with full headlights at all times and, in the spring, plan to rewire the heads to go on and off with the ignition.
2009 PONTIAC G8
vibe2003
Post by vibe2003 »
damn, i want to disable the DRL, but want just the headlights to trun on automaticly, not those signal light to turn on auto.
ragingfish
Re: (vibe2003)
You can't have headlights without parkign lights...it's illegal.
2009 PONTIAC G8
vibe2003
Post by vibe2003 »
mornign the head light turns on only and that's illegal?
vibe2003
Post by vibe2003 »
i fixed the DRL and can you tell me what is ballast does? also, i'm seeing white HID color instead of blue colors now, why is that?do i need to put this back on when i have my HID?what is the diffrent between h4, h6, h3, ect..?
ragingfish
Re: (vibe2003)
Quote, originally posted by vibe2003 »i fixed the DRL and can you tell me what is ballast does?The ballast steps up the 12V to the necessary 20,000V used to create the gas discharge that creates the light.Quote »also, i'm seeing white HID color instead of blue colors now, why is that? HID is supposed to be white. What color temperature did you buy?Quote »do i need to put this back on when i have my HID?YES. That keeps water from getting inside the headlight assembly. If water gets in and hits those bulbs, they will shatter instantly.Quote »what is the diffrent between h4, h6, h3, ect..? The bulb style. Base, number of filaments, wattages, etc.
2009 PONTIAC G8
vibe2003
Post by vibe2003 »
my bodyshop told me that i don't need that thing that protect teh light from water. is that true? i'm using 8000k. also, what bulb is best ?
Merzbow
Re: (vibe2003)
Post by Merzbow »
That looks sweet...I wish they didn't cost 8 billion dollars or I'd get some.
http://www.cardomain.com/ride/541918-1999 Infiniti Q45t-2003 base Vibe (Rest in peace my love)-2002 Ducati Monster 620 Dark
Jahntassa
Re: (vibe2003)
Post by Jahntassa »
Quote, originally posted by vibe2003 »my bodyshop told me that i don't need that thing that protect teh light from water. is that true? i'm using 8000k. also, what bulb is best ?Then make sure your bodyshop signed a paper saying they'll pay for any and all damages if anything contaminates those headlights, because you'll need new bulbs, possibly new ballasts, and you'll need to clean all the bulb parts from the lens after it shatters. That rubber there keeps EVERYTHING out of the lens. You also stand the chance of permanent condensation in the lens without that on.The Vibe uses H4's in the headlamps. That's it. Color temperature (8000k) is personal preference.
vibe2003
Re: (Jahntassa)
Post by vibe2003 »
the reason i can't put on that thing that protect from water is cause the wires and the caps is blocking it. here's some pic. Is there any other wy i can protec the bulbs?
ragingfish
Run the wires through it. It's doable. Both Jahntassa and I replaced that cap after installing HIDs.
2009 PONTIAC G8
Psychobroker
Re: (ragingfish)
Post by Psychobroker »
$600? eep...I hate to link this, but, there's a sweet plug-n-play HID GB going on over at matrixowners.com right now: http://www.matrixowners.com/fo...37227 - $260 shipped for 5400k (i think?)Looks awesome though!
damronjr
Re: (Psychobroker)
Post by damronjr »
Quote, originally posted by Psychobroker »$600? eep...I hate to link this, but, there's a sweet plug-n-play HID GB going on over at matrixowners.com right now: http://www.matrixowners.com/fo...37227 - $260 shipped for 5400k (i think?)Looks awesome though! Sounds like he said no to Vibes, at least for right now.
Psychobroker
Re: (damronjr)
He didn't say no, and actually, I rec'd a PM from one of his partners offering the deal. I don't see why it wouldn't work, so long as you ordered either H4 or 9003, right?Stock wiring should be the same...
vibe2003
Post by vibe2003 »
Can a vibe get a bulb 9006, instead of h4? I know this already been said, but i want to make sure.
damronjr
Re: (vibe2003)
Post by damronjr »
Quote, originally posted by vibe2003 »Can a vibe get a bulb 9006, instead of h4? I know this already been said, but i want to make sure.Headlights are H4 or 9003 and fogs are 9006. Please correct me if I'm missing anything.
vibe2003
Post by vibe2003 »
so this car has 9006 and it's not for fog light. i want this bulb, if that possible? this pic is from matrix owner.
DavidPIL
Re: (ragingfish)
Post by DavidPIL »
Hey ragingfish,Quote, originally posted by ragingfish »I personally have become accustomed to driving with full headlights at all times and, in the spring, plan to rewire the heads to go on and off with the ignition.Don't rewire, just pop off the cap to the sensor and place something like black tape or something in the plastic cap. I did that and have lights 24/7. Then if you ever want to change it back, just tape the tape off from inside the cap.Dave
Smokin' Rubber
Re: (vibe2003)
Quote, originally posted by vibe2003 »so this car has 9006 and it's not for fog light. i want this bulb, if that possible? this pic is from matrix owner.The bulb size isn't what affects the color. All getting a 9006 bulb would do would change the shape or size of the bulb not the brightness or color.
millster
Re: (vibe2003)
Post by millster »
Quote, originally posted by vibe2003 »so this car has 9006 and it's not for fog light. i want this bulb, if that possible? this pic is from matrix owner.I think what you're wanting is the 6000K color temp, not the 9006 bulb.Edit:And as usual, I'm a little slow on the reply...Oh well, between the post above and this one, that pretty well answers it.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
1986 Jaguar XJ6 Vanden Plas (GM Drivetrain Conversion)
2007 Outback XT EJ257 2.6L Build
vibe2003
Re: (millster)
Post by vibe2003 »
6000k is white, but why the pic from matrix owner has 6000k and the bulb is 9006? i don't get it. Is it the bulb affect the color or the temp?
millster
Re: (vibe2003)
Post by millster »
The temp affects the color. The bulb just affects the shape and size of the glass tube itself.
-Millster-
vibe2003
Post by vibe2003 »
ah that's what i thought. ok, now i put the thing that protec from rains, but will the bulbs produce gases cloge up inside the headlamp?
Smokin' Rubber
Re: (vibe2003)
Quote, originally posted by vibe2003 »6000k is white, but why the pic from matrix owner has 6000k and the bulb is 9006? i don't get it. Is it the bulb affect the color or the temp?The car in the picture isn't a matrix first of all it's probably a corolla which has different bulb sizes. And just like photos often do, the color is probably a bit off. It is also possible that the person who made the photo mislabeled 8500k HID's since that is what they look like to me as well. Most 8500k lights I have seen are whitish blue, but not pure white and 6000k is basically "pure" white.EDIT: Lol this time I got the late postNo, the gases are contained within the bulb itself and should not leak into the headlight compartment unless they are cracked somehow and if they were they probably wouldn't light correctly anyway. Also, the gas is transluscent so even if it did get into the main assembly of the headlight you wouldn't be able to tell.
ragingfish
Re: (DavidPIL)
Quote, originally posted by DavidPIL »Hey ragingfish,Don't rewire, just pop off the cap to the sensor and place something like black tape or something in the plastic cap. I did that and have lights 24/7. Then if you ever want to change it back, just tape the tape off from inside the cap.DaveI had to disable DRL to install HID, and when you kill DRL, you kill auto headlights too...
2009 PONTIAC G8
ragingfish
Re: (vibe2003)
Quote, originally posted by vibe2003 »ah that's what i thought. ok, now i put the thing that protec from rains, but will the bulbs produce gases cloge up inside the headlamp?No. These don't give off anythign besides light and heat...and less heat than a regular bulb. Put the covers on, do't worry.
2009 PONTIAC G8
