ok, my in Injen CAI is installed but I have a major problem, the rpm's are going back and forth between 1500 and 2000 as it idels, it revs back and forth between the two numbers, doesn anyone know what it could be? Everything seems ok except for that? Any ideas???
Does it do this when your car is cold? If it is, then it should calm down once the car is warm. Make sure also that MAF sensor is on securely. JMHO. Inder Singh
2008 Chevy Cobalt SS Turbo - Fun stuff under there somewhere 1998 Nissan Sentra - Sold2004 Pontiac Vibe - 107k and SoldCosmo CAI
did you check to make sure you hooked the lines up right? I know those GTs have a few lines, wrong ones in the wrong place would be easy to do. My base had one line.
Quote, originally posted by silvervibeGT »ok, what did you do to fix it?this is what it should look like it is a pic of my vacumn hoses on my '03 base vibe. I don't know about a '04 or newer with the smog pump. I hope this helps.
Quote, originally posted by scherry2 »this is what it should look like it is a pic of my vacumn hoses on my '03 base vibe. I don't know about a '04 or newer with the smog pump. I hope this helps. He has a GT I think it has more connections than a base.
Quote, originally posted by scherry2 »Unhook the battery for a few minutes and clear the cel. how much different is a gt than the base? It is quite different from the base vibe, especially the 04 GT with that new smog pump. I'd recheck all your connections. Swirv had troubles with his CAI on his 04 GT...one of the hoses that connect to that smog pump was crimped, causing a CEL. Just re-check everything again, make sure it's all hooked up correctly.
Used to have: 04 Monotone Abyss 5 SpeedNow the proud owner of a black 2005 SRT-4230 Hp250 lb/ft torque
on the short ram i installed on my gt i hooked up the largest diameter vacuum hose that was part of the air box into that spot and capped the rest off. Works just fine after 3000 miles.
ALi3N aka Dj ViP3RThere is a force through the euphoric beat causing uncontrolablemovement of your body, I am that force. Take a journey beyond the limits of your mind.'Download Mixes:http://shlrm.org/DjViP3R/http://www.myspace.com/djvip3r Latest Mixes: 'Nightlife' & 'M0Ti0N -X-'Pimpin' Abyss Vibe GT w/ Nav
