Removing carcasses from radiator...
ragingfish
Post by ragingfish »
I was going to use a stiff-bristled brush or broom head to brush all the dead buggies outta my radiator...that's sturdy metal, right? I don't have to worry about damaging it?
2009 PONTIAC G8
cohocarl
Re: Removing carcasses from radiator... (ragingfish)
Post by cohocarl »
I'd be very careful if I used a brush. Those fins aren't that sturdy. I take my hose and get out what I can with that and call it good.
Sold 6/16/04 03 Vibe 5-speed, Hotchkis Sway Bars & Springs, Hooker Aerochamber, Panasonic Stereo, Hitch, Silverstars,04 Saturn Vue 2.2L Ecotec, 5-speed, 01 Stratus R/T Coupe 5-speed (wife's car) 85 Corvette 268 CompCam, 882 heads, FlatTops, 24lb injectors, Hooker Aerochamber true duals, 58mm TB, Holley AFPR, Siamesed intake base, Polished TPI.
I haven't messed with the Vibe radiator, but have with other radiators. They had very thin bendable fins and it was easy to fold them over, effectively blocking air flow through that spot. A lot of copper in them which is a soft metal. As long as it's not a wire brush, you should be able to do it if you move the brush parallel to the radiator fins, but I would recommend not going across them.IMHO
ragingfish
Hmm...glad I asked first!
2009 PONTIAC G8
dmitri
Post by dmitri »
a soft broom wouldnt hurt it. be careful with the hose using too powerful of a spray too. use a soft bristle brush or something to get it out.
scherry2
Re: Removing carcasses from radiator... (dmitri)
Post by scherry2 »
use a spray hose only the fins are thin and will bend easy. the more bent fins the less cooling.
Toasted7
Post by Toasted7 »
Sounds like someone is getting their Vibe ready for the Ohio Meet... am I right?
VMFIC of Cincinnati Scikotics Cincinnati Scikotics sponsored by: KerryScion.com My other ride is your mom
AKLGT
Re: Removing carcasses from radiator... (Toasted7)
Post by AKLGT »
i use the power wand down the car wash. it gets most of the little buggers out.
AKLGT1998 Subaru 2.5RS
robdog
Post by robdog »
I must say that all the cars I have owned I have never had a problem with excessive bugs on my radiator. Maybe some of you others live in a more bug prone area than I.
03, Abyss monotone GT, 6 disk changer, moon and tunes, Cargo mat/nets, power package, side airbags, AEM Short Ram Intake, Borla exhaust , 35% tint all around, F1 strut tower brace, debadged, 17" Excel rims w/ federal ss595 tires.
Stang2Vibe
Re: Removing carcasses from radiator... (robdog)
Post by Stang2Vibe »
Depending on the car, I get a fair amount of bugs, too. I would suggest, as someone already has, to take the car to a self-car wash and use a high-pressure washer to spray them off. Just don't get the nozzle end of the power washer too close to the radiator and the fins won't bend. I use the power washer at work all the time for this purpose, but I haven't tried it on my Vibe yet. The sooner you remove the bugs, the easier they will be to squirt off. If you squirt off the radiator with your hose at home every time you wash the car, they won't build up and should come off pretty easily.
Weirdest thing I ever found plastered to the front of my radiator was a bat. Was in a different car, doubt if a bat could get through the Vibe grill.
cool vibes
Post by cool vibes »
What you can do is install a piece of window screen in front of the rad for the summer""""
good vibes
Re: Removing carcasses from radiator... (cool vibes)
Post by good vibes »
or you could chuck a wire brush into a drill and go at it for a while. then you can smear peanut butter all over it to make it shiney again!
My Car: 2003 Vibe AWD Shadow/Graphite My Options: Vibe Rubber Floor Mats, Vibe Back Seat Pouches w/ First Aid Kit My Extras: Anti-Fatigue Mat Cut To Fit, PIAA H4 Headlights, grafixwerks stuff, yakima bike blocks, roof rack with land shark for my kayak, and loadwarrior, hella tripple tone air horns (wanna hear a loud horn? get these!) Rockford Fosgate fanatic 6 1/2".
scherry2
Re: Removing carcasses from radiator... (good vibes)
Post by scherry2 »
quote:or you could chuck a wire brush into a drill and go at it for a while. then you can smear peanut butter all over it to make it shiney again!MMMMMMMM PEANUT BUTTER. ROFL
Raptor-vibes
Post by Raptor-vibes »
My suggestion is to use a light pressure nozzle and spray from the engine area out this will push the buggy guts out. To reduce the bugs in your rad add a screen between your front grill and rad. But HEY what do I know I just work on tanks for a living!! HA! HA! HA!
My 2004 Is One Mean Vibe!!!!!
