Please do not light me up for talking about this product before reading the whole post. A friend of mine bought a E-Ram. It's a electric super charger. I didn't figure it was going to do anything but he wanted to try it so he did. This is what he found.quote:Alright, tried the E-RAM this weekend. I didnt bring it to the dyno, I did about 10 G-TECH runs with and without it on the same stretch of road.The E-RAM should be mounted behind the MAF on MAF cars as it WILL screw up the reading significantly.On the MAP based accent GSi, the MAP sensor reads a +.9 psi at idle and a +.3 psi at WOT (6000 RPM). It gives about 4-5 WHP on the accent and I read as high as 12 WHP on the Tiburon. However consistently I was reading 8 WHP, 138 to the wheels with it and 130 WHP without the E-RAM (with 2900 lbs wieght entered). Keep in mind that my tiburon has a full breather system (I/H/E). The accent just had the CAI.I couldnt feel the E-RAM power up when I turned it on, however at high RPM the car did not lose power as it normally would, the power stayed strong until redline (6500 RPM).The E-RAM draws only about 30 AMPs when working at WOT, but at idle if turned on, it could blow the fuse, as its working harder drawing the whole 50. Also the inline fuse provided with the E-RAM is crap, the fuseholder burnt out on the first run. Not the fuse, the fuse holder. Couldnt figured it out, there was conductivty through the fuse holder, but the internal resistance had climbed so high that it would only let about 1 amp though.... So it got cutout, .Also the current that the E-RAM draws comes entirely from your alternator, not your battery like the site claims. Your alternator is CHARGING your battery at around 14.3 V. Your battery with the car off is at most 13.0 V. With the E-RAM on the system voltage with the car running, dropped to about 13.9-14.0, meaning that no power was being drawn from the battery, also you could feel the alternator working harder when you powered it up. (As if the dim interior lights didnt give it away).I had the E-RAM blow off the CAI twice, and the results were not consistent, but it did provide the gains it claimed.For now, the E-RAM is being mounted on the accent GSi.We figured out the reason it blew off the TB a couple times was because the TB was closing before the E-Ram shut off. Were working on that and will keep you posted. The E-Ram comes with a switch so that it only comes on at WOT.The E-Ram does what it claims. I'm making no money for saying this I have seen the prove. Is it worth $300 for 8 to 10 WHP, maybe that's a pretty good gain really. Here is the E-Ram website
http://www.electricsupercharger.com
