17 inch wheels
dmitri
17 inch wheels
Post by dmitri »
Im gonna get 17's when i get my new wheels. Should I upgrade the brakes since with the bigger wheel the disk will spin less? When you order the vibe from the factory with 17's does it come with bigger brakes?
millster
Re: 17 inch wheels (dmitri)
Post by millster »
No, my brakes are the same as everyone else's. Judging from that, I'd say you're safe. Also, I believe the 17's from the factory wind up the same diameter as the 16's since they're a lower profile tire.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
NovaResource
Post by NovaResource »
quote:...since with the bigger wheel the disk will spin less?The larger wheel does not spin the rotor less. When you get new tires for the new wheels, the overall diameter of the new tire will be the same as the old tire.
dmitri
Re: 17 inch wheels (NovaResource)
Post by dmitri »
u sure????
millster
Post by millster »
It's true, but think of it this way too. If the rotor were spinning slower, would that not make it easier to stop? If you're not increasing the overall diameter of the wheel/tire combo, you're not affecting the rotational speed of any components. However, even if you did change the overall diameter, the only real effect would be a loss of speedometer accuracy.
-Millster-
NovaResource
quote:u sure????Yes. Remember, the car rides on the tire, not the wheel. Vibes with 17" wheels have 215/50-17 tires while Vibes with 16" wheels have 205/55-16 tires. Both have almost exact same diameter and circumference.
ragingfish
Post by ragingfish »
He's right. If you measure the outside diameter of the tire with both the 16's and the 17's, it should be nearly, if not, identical.
2009 PONTIAC G8
good vibes
Re: 17 inch wheels (ragingfish)
Post by good vibes »
correct all around. the only way you will get a different rotational speed is if you change the outside diameter.
My Car: 2003 Vibe AWD Shadow/Graphite My Options: Vibe Rubber Floor Mats, Vibe Back Seat Pouches w/ First Aid Kit My Extras: Anti-Fatigue Mat Cut To Fit, PIAA H4 Headlights, grafixwerks stuff, yakima bike blocks, roof rack with land shark for my kayak, and loadwarrior, hella tripple tone air horns (wanna hear a loud horn? get these!) Rockford Fosgate fanatic 6 1/2".
shibaman
Post by shibaman »
I switched from oem 16" Contis to oem 17" Bridgestones. The 17" 215-50-17 are .9" taller than the 16" tires. Tire size can vary from brand to brand. A good way to check tire sizes is at the Tire Rack web site.
Salsa basemoons and tunesInjen CAIHotchkis sway barsHotchkis springsCenterline RPM sMagnaflow muffler,stainless tipDevlop's custom STB
NovaResource
Re: 17 inch wheels (shibaman)
quote:I switched from oem 16" Contis to oem 17" Bridgestones. The 17" 215-50-17 are .9" taller than the 16" tires.215/50-17 = 25.46" tall205/55-16 = 24.88" tallThat's a difference of only 0.6", not 0.9".
aggie_vibe
Post by aggie_vibe »
The stock difference in tire diameter is odd considering there are other tires that would work (225-45-17).
'04 Satellite base Pontiac Vibe (found!)'02 Sebring Silver Honda S2000
shibaman
Post by shibaman »
I guess that I can't do the new math! If you check tire specs at the Tire Rack you will see that tire sizes vary a bit from brands and tires. Depending on the tire the 16" and the 17" can vary between .5 to .9" The Bridgestone RE92 is on the taller range. The 215-45-17 would work and be closer to stock hight(16") or slightly shorter.
