Trying to put Sony reciever in Vibe!!!!!Help!!!
carterwood
Post by carterwood »
I am trying to put a Sony reciever in Vibe..got the gm harness and face kit from Crutchfield...hooked it all and boom..no sound..well..I got the cd player with moons and tunes package.and it has the amplifier 6 speaker system...how the heck do i hook this up..do I need to hook into the amp..will it work even though the sony is pushing 200 watts too...will the impedence be off? Help.....has anyone ran into this problem yet??? I am about to pull my friggin hair out..I have installed car stereos for years and this one has me stumped. carter
SCTM
Re: Trying to put Sony reciever in Vibe!!!!!Help!!! (carterwood)
Post by SCTM »
If this could help a little, some pics "how to" ... for you.http://forums.genvibe.com/zerothread?id ... id=932good luck on wiring.
SCTM QUÉBEC Base 5spd Satellite, 20-35%back-tint, 3M film, HiddenHitch, Motegi Racing MR8, Orbit Remote Starter/5Doors, Winter GoodYear UltraGrip ice... and Lawnmower 310CCA battery !
carterwood
Re: Trying to put Sony reciever in Vibe!!!!!Help!!! (SCTM)
thanks for the help dude......but I know all that stuff...my problem is I get it all hooked up...my sony harness to aftermarket harness...then plug in..there is no sound.....when you look at the harness from the vibe..it has more wires going into it than the harness from the radio does......and the amp is not getting power and I was wondering who has ran into this problem..I got a tech at work thinking I should bypass amp or go with another.
carterwood
ok..I am stupid...I didn't read page 2 of one the links you gave me..it explained everything...THANKS..I appreciate your quick reply
carterwood
ok....maybe it didn't help.....seems locdog has done but can't reach him..I got the same reciever as him......has anybody else put a reciever in there Vibe that had the stock amplifier. Dayvid
Idsane
Post by Idsane »
It looks like you didnt use the remote power turn on lead from the original head unit. I believe it is a white wire that is hooked up to the original head by a different harness. The adapter harness does not account for this wire. You need to splice into your remote turn on wire coming out of your new sony unit (usually blue). This sends a small signal to the amp to say "hey, I am on, you should turn on now too". This is so the amp is not always on and draining power when the head unit isnt on. Hope this helped.
Idsane
Re: Trying to put Sony reciever in Vibe!!!!!Help!!! (Idsane)
Post by Idsane »
Also since your sony is putting out a little more power than the stock headunit, it may be too much for the high level inputs on the stock amp. If you are hearing a lot of distortion, this is prob why. Most aftermarket amps that have high level inputs would be able to handle this (since your sony is really only pushing 15-20 watts RMS), but I have no idea about this little stock amp. It should prob be fine, just wanted to give you a heads up!
LocDog
Post by LocDog »
Hey sorry i've been slacking... I got my radio installed at Best Buy, but I watched the whole thing. The seperate wire in the smaller harness was disregarded in the installation. When the wiring was done, the guy added this white inline cylinders which resist the output of the receiver. I have the moons and tunes and the factory amp has caused a problem. The signal is too ampified, i get alot of distortion when I raise the volume to 50%. The tweeters start poping and the speakers crackle. I should warn you, i blew out all the speakers excluding the tweeters and front passenger door speaker. I am still looking for a better way to set up my system, probably by bypassing the factory amp.If you connected the radio to the harness without any inline resistors, you might burned out the factory amp and thats why your not getting any sound. Try puttin in the old radio and see if the amp still works.If you find a way to bypass the amp without having to rewire the speakers let me know... If you get it to run, theres a very good chance your gonna blow out the factory speakers. I already had to get replacements from the dealer.If you have any more questions feel free to ask.
-aBySS Monotone Vibe-Auto Everything (I wanted a manual)-Moons and Tunes-No Badges-No Lateral Bars-Sony CDX-M730 Head Unit-200w PPI Amp Powering a 12" MTX Sub-9 1/2'' Stainless Steel Trumpet Air Horn-Spare Bridgestone Blizzaks Mounted on the Cheapest Steel Rims Ever
Sub-Vibe-R
Re: Trying to put Sony reciever in Vibe!!!!!Help!!! (LocDog)
Post by Sub-Vibe-R »
Have you try to use the pre-amp output (usually RCA) instead of the powered output from your head unit? Pushing 50w in an amp. is not realy good. Try by hooking the amp input to the RCA pre-amp output of your head unit. 50W at 4 ohm means 12.5V in the amp input. Most of aftermarket head unit have a pre-amp output between 3V and 5V. Using the pre-amp output should resolve your problems.
SCTM
Post by SCTM »
Don't worry Carter, there's nobody STUPID, down here, just ANXIOUS to get our lovely VIBE the way it deserve... LOLYou're on the right track right here on genvibe. Good Luck
