keithvibe wrote:photo would help/ You can get new Orings at most parts stores and even in the plumbing section of Homedept or lowes.
It has stock injectors, I believe the sc kit comes with larger ones but they were never installed... so I'm just upgrading from the old injectors, and yes I believe my 5th injector is working fine, and no not yet I'm still running trd for now, once I get everything I need injectors ect... I will check into a diffrent type of engine management other than trd.Salsa Guy wrote:My question is why are you putting them in? As long as your 5th injector is working correctly it shouldn't be a problem. Are you running another type of engine management other than the TRD?
FYI I have an AEM FIC for sale. Also when you say 200hp are you meaning at the wheels or Crank? You might be able to get 200hp at the crank (about 180whp) with the TRD SC but that would be a push. When you start overdriving (using smaller pulleys) these little TRD SCs they get very inefficient and will fail sooner.krazie805 wrote:Well soon I will be looking for an alternative to the trd. I just plan on building the car to around 200hp.
