Backup camera system for 2009 Vibe
MikeFAA
Post by MikeFAA »
I am about to purchase a 2009 Vibe. I would like a backup camera system that will not disable Onstar. One shop offered to replace the current Monsoon radio/CD with a different system with a camera for about $800. However, I am looking for a $300 solution. Does anyone have a recommendation?
Re: Backup camera system for 2009 Vibe (MikeFAA)
You can get the add on rear view mirror systems for around $100 that attach to your current mirror. They won't interfere with the Onstar, but they might make the buttons harder to reach. You should be able to mount it in a way that the buttons are still accessable between the two mirrors though.This is one, but I've seen them cheaper on Amazon. There is also another thread on here about this.http://www.target.com/p/Peak-R...ci_kw=PDF manual for this one:http://www.peakauto.com/pdf/manual-PKC0RG.pdfAnd here is the thread:http://forums.genvibe.com/zero...53185
mr.clutch
Post by mr.clutch »
if you like the peak system I have one that I can sell you It is still in the package un open. It uses a seperate 3.5 in. monitor (still wireless) you can put monitor on the backside of your visor.don't have time to post pict.of it now but unit mod # is PKCORB will sell for $60.00.
firestorm
Post by firestorm »
Can't figure out how to PM here. Mr Clutch - you still have the backup camera? I'd be interested in buying that from you...
