Key Fob
pperrone
Key Fob
Post by pperrone »
Looking to get a replacement key fob. All the ebay listings have an FCC ID number. I do not have the original. Can anyone help me figure this out?Thanks,P
Pete'05 Stock Salsa
09vGT
Re: Key Fob (pperrone)
Post by 09vGT »
As long as its for your listed model it should work. I toyota one would probably work too. But again, this I'm not 100% sure on.
djkeev
Post by djkeev »
My 07 FOB is FCC ID C043VT14T
(o ! /o) (o)=I=(o)
Quote, originally posted by pperrone »Looking to get a replacement key fob. All the ebay listings have an FCC ID number. I do not have the original. Can anyone help me figure this out?Thanks,P Didn't need any FCC stuff when I ordered my 09 spare FOB key for one of our Vibes. Had a friend cut it, then programmed it. All went well and exactly as the instructions said.
Attached files KeylessReplacementRemote.pdf (101.7 KB)
ehoff121
Post by ehoff121 »
You can get either your 2005 Vibe's remote (as listed on ebay) or a 2005-7 Toyota Matrix remote.With the Matrix remote, you get a panic button on the back that works on the Vibe, but it has a mini Toyota logo. The Vibe remotes don't have a panic button or a logo.I have and use both: the FCC ID's are identical - both made by TRW - GQ43VT14TIt's hard to read, but it's the same remote for 2007's, djkeev: GQ looks like CO - I had to check because I couldn't see it that well
djkeev
Re: Key Fob (ehoff121)
Post by djkeev »
Quote, originally posted by ehoff121 »I have and use both: the FCC ID's are identical - both made by TRW - GQ43VT14TIt's hard to read, but it's the same remote for 2007's, djkeev: GQ looks like CO - I had to check because I couldn't see it that well I wondered if it was 100% accurate! I almost put in a disclaimer! Hey, I'm old and those little teeny tiny letters are getting harder and harder to see!Got out a magnifying glass, man! Tha GQ still looks a LOT like a CO but close enough!! Thanks for the correction.Dave
(o ! /o) (o)=I=(o)
silverbullet
Post by silverbullet »
Yep, got one for my 03 and just ordered a vibe one from ebay works great. Now here's the funny part. The one they sent me has a Toyota emblem on back. Matrix I guess? It has a panic button too. I don't think the original did, and yes it works.
