Speedometer and instrument panel trouble. Help me
wecafinas
Post by wecafinas »
Greetings colleagues. I do not know if this is the place to get help on this topic. I apologize if it is not.I have a problem that concerns me personally. My odometer (speedometer) does not move, does not work, do not mark anything, mileage does not change.I wonder how to fix this. I do not know if it's an electronic problem, or a mechanical problem. If you were so kind to tell me the exact position of the speed sensor, it is probably the solution to my problem, checking the wiring.On the other hand, do not know if this problem somehow affects development speed of my car, and I'm having some jams when accelerating.It is worth clarifying that I bought my car recently, side stroke, and am in process of solving problems with several signals in the instrument panel, such as BRAKE, and the Tire Pressure Monitor System.Another problem I have is that my ABS module broke, I had to opt for working in a mechanical brake. I know I can not remove the ABS signal from my dashboard. I need to buy a new one, but here in my country is not sold in yonkers or dealership. Hopefully someone here I could sell ABS module in good condition, I would pay the shipping and the price obviously.Honestly, I pray help me, guide me, since I have no enough money to take my car to a dealer.Thanks for reading and for your future answers.
My project since 01/05/12
dgekiere
Re: Speedometer and instrument panel trouble. Help me (wecafinas)
Post by dgekiere »
took his out of the gm manual. looks like the spedometer goes through the abs module. since yours is broke, it looks like that is why your speedometer is broke.i cant find the wire diagram of how it works.hope this is some helpSpeedometer On a vehicle without ABS, the instrument panel cluster (IPC) displays the vehicle speed based on the information from the vehicle speed sensor (VSS) indicating the vehicle speed. On vehicles with ABS, The IPC calculates the vehicle speed based on the message indicating the wheel reference speed from both front wheel speed sensors. The wheel speed sensor signal is sent to the IPC through the electronic brake control module (EBCM).
2003 VIBE GT, CONVERTING TO RALLY CAR. http://forums.genvibe.com/zerothread?id=463112004 vibe gt magnaflow catback exhaust (bought totaled 9/06 with 1600 miles, fixed it and in love ever since2004 HONDA CBR1000RRASE Master certified mechanic
wecafinas
Re: Speedometer and instrument panel trouble. Help me (dgekiere)
Post by wecafinas »
Hey. Thanks for responding.Certainly, I have indicated that this is the problem, but as I noted in your owner's manual, supposedly the speedometer is separate from the ABS, but then told me the speedometer ABS module depends. Have the wire I have a diagram, I will try to verify.You are very kind to tell me the operation of the speedometer with the ABS.Still, I wonder if someone in the forum, could sell ABS module, because in my country are not easily found.Again, thank Dgekiere friend.
wecafinas
Post by wecafinas »
Hello again.Please friends, I beg, I beg ...If any of you know of a website in which I can buy a ABS MODULE 2006, or if any of you could sell me one, obviously used. I've been several days asking for, but it seems that nobody knows, at least I would like to know if anyone can help me.You don't imagine how difficult it is for me in my country get that part.
