Does Manual Transmission Fluid Need To Be Changed?
tots
Post by tots »
Hi -I have a 2004 base with a 5 speed manual tranny. I have seen many threads about changing manual transmission fluid on this site, but the 2004 owners manual states:"Manual Transaxle FluidWhen to CheckA good time to have it checked is when the engine oil ischanged. However, the fluid in your manual transaxledoesn’t require changing"I understand that under severe conditions (such as towing), a change may be required, but is a change needed for normal conditions? I have 118K miles, it has never been changed.Thanks.
My Vibe: 2004 Base, Fusion Orange, Mono, ABS, Power.16" Alloys, Factory Alarm, Side Air Bags. Cargo Box
Re: Does Manual Transmission Fluid Need To Be Changed? (tots)
It does not hurt to change it. On my Mustang I change it probably once every 2 years or so. It does collect moisture and starts to get harder to shift, so then I change it.
sideshowalan
Post by sideshowalan »
You absolutely should change it. Especially on the 03/04 5 speeds which are known for premature failure. I'd recommend a 30K mile interval at this point. Redline MT-90 is great stuff. Just do a drain & fill, don't let anyone 'flush' it.
2008 Pontiac Vibe
2008 Toyota Sienna XLE
Bedlam
Re: Does Manual Transmission Fluid Need To Be Changed? (sideshowalan)
Post by Bedlam »
Quote, originally posted by sideshowalan »You absolutely should change it. Especially on the 03/04 5 speeds which are known for premature failure. I'd recommend a 30K mile interval at this point. Redline MT-90 is great stuff. Just do a drain & fill, don't let anyone 'flush' it.^ this is exactly right. keep on top of this if you want it to last. Penzoil syncromesh is fine for 90% of people in those transmissions.
07 1ZZ 5spd Stealth - Sold
03 1ZZ 6spd Shadow w/NAV - For Sale
06 AWD Stealth - Current
07 Magnum SRT-8 - Current
Serj22
Re: Does Manual Transmission Fluid Need To Be Changed? (Bedlam)
Post by Serj22 »
I put new gear oil in my 04 when I swapped the clutch out 3k miles ago, just seemed like the right thing to do. Plus some of it leaks out anyway when you pull the cv's.
Pioneer HU2 x D3tAK tweeters in stock location (M&T)4 x Diamond Audio D162.5i1 x Pioneer TS-W309S4 SubPolk Audio Pa330 (To drive Sub)
tots
Post by tots »
Thanks for advice all. Any idea why the owner's manual says it doesn't need to be changed?
Serj22
Post by Serj22 »
Probably because its just gear oil. Its simple stuff. Probably why a lot of auto stores around me dont even carry it on the shelf, they get it from the back.
circuitsmith
Post by circuitsmith »
Quote, originally posted by tots »Any idea why the owner's manual says it doesn't need to be changed?The marketing depts want to give the impression that their cars have low maintenance costs.So they tend to only recommend upkeep that get the car through the warranty period.Thus we get craziness like "lifetime" transmission fluid/oil or Honda's mistake recommending valve lash adjustment at 105K on the CRV when it really should be done at 30K.If you really want to keep your car a long time you should also change brake fluid every 3 years and drain $ refill the power steering reservoir once a year.Don't keave the spark plugs in for 100K+, they can get frozen in place, change every 60K.
2006 Matrix 5-sp
