Hey all,I'm installing a Pioneer DEH-33HD into my 2007 Pontiac Vibe w/ M&T. I just spiced the HU harness to the metra harness I bought, plugged it all together and the head unit turned on but isn't giving me any music. I suspect that the wires on the metra harness don't line up with the stock harness on the car and want to double check everything. Does anybody have a diagram for a 2007?Any other ideas why the music may not be sent to the speakers when the HU turns on/seems to function fine?Thanks,rgnjc
2005 Vibe base AWD w/ M&T, 191k miles (as of 8/2022)
2007 Vibe base FWS w/ M&T, 150k miles (as of 8/2022)
OK I basically found the necessary information I was looking for, but in case other people are curious:In-dash harness wire identification: http://forums.genvibe.com/zerothread?id=31372Why I don't have sound: http://forums.genvibe.com/zerothread?id=19021Basically, my crappy metra harness didn't have a white/blue amp lead and I am going to have to work around this. When I did a HU upgrade on my 2005 vibe the metra harness DID have a blue/white amp wire and I didn't have this. I should have recognized that the harness didn't have one for the amp. Duh.
So i pulled one of the extra dimmer pins/wires out of the harness and moved it to spot B3 and connected it to the blue/white wire (amp power) on the HU harness and connected everything and that solved the issue.
