No sound after head unit install (moon and tunes + xm + factory subwoofer)
92blacktt
Post by 92blacktt »
Installed a new head unit and now I have no sound. I have an amp turn on wire on pin A3 but still does not work, any ideas?I also have a red with white stripe on my harness adapter (but no label on the wire so I have no idea where it would go). There was also a black with white stripe labelled as amp ground (I hooked it up to head unit ground).Any ideas?
92blacktt
Post by 92blacktt »
pin A6 has a red with white stripe but no writing on it for what it is
92blacktt
Post by 92blacktt »
Found a pin out but don't know what some of these mean:A1 - Class 2A2 - Class 2A3 - SW_PWRA4 - FM_DET+A5 - GNDA6 - ASWC_REF_OUTA7 - RUI1A8 - LF+A9 - LF-A10 - RR-A11 - RR+A12 - GNDB1 - BattB2 - IGNB3 - ANTSPLYB4 - DIM+B5 - DIM-B6 - AMP_SENSEB7 - RUI2B8 - LR+B9 - LR-B10 - RF-B11 - RF+B12 - PARKM - AUX_MON+L - AUX_MON-K - AUX_COMJ - LAUXINH - RAUXING - CLASS2A - CEL_TEL_MUTEB - Not used (Test Point)C - GNDD - GNDE - Not Used (Test Point)F - Not Used (Test Point)What should I hook up B6 and A to? I don't have a wire on A5
92blacktt
Post by 92blacktt »
I have sound now, had to move the remote turn on from A3 to B3, but I have a loud hiss when the unit is on. Any ideas how I can fix this?
92blacktt
Post by 92blacktt »
Do any pins on the harness need to be grounded for the amp?
