Replacing temp control dash light.
MSAGRO
Post by MSAGRO »
How do I get behind to replace? I did the search, but no luckStep by step will help as will a link and access to get replacement bulb.
455SD
Post by 455SD »
Thread is here. Try to to when Vibe is warm on the inside. The plastic tabs/fingers that attach the control to dash are brittle, and the cold makes them more so.http://forums.genvibe.com/zerothread?id=17244
EnvyGreen03
MSAGRO
Re: (455SD)
Post by MSAGRO »
Thanks very handy site. Question. What size bulb does it use?Also, will and LED bulb work without a resistor? Or is it 'plug n play'?
455SD
Re: (MSAGRO)
Post by 455SD »
I haven't looked aftermarket for this, so I personally don't know of anything other than OEM part that will work. Going with Toyota for the parts our Vibes use, is the least expensive. Maybe someone will pipe in with the question about LED usage.Here's the Toyota part number: 90072-02005
EnvyGreen03
