Passenger floor pooling rain water.
RodDoe
Post by RodDoe »
I had pulled back the matting on the passenger floor of my 2003 Vibe. There is a hole used to tunnel sensor wiring from the outside to the inside. Rain water is seeping into this hole at a good clip. Not coming from an a/c hose. It seems bizarre that water could pool there. Looked under the car the passed weekend-couldn't see any reason how water would accummulate there. I am not getting it!What the Freak!
ehoff121
Re: Passenger floor pooling rain water. (RodDoe)
Post by ehoff121 »
Welcome to GenVibe!Just curious, what did you do to rule out the A/C drain hose? Have you had the A/C on at all recently?
Might you have a sunroof?
RodDoe
Post by RodDoe »
Yes I do! Don't see how the rain water is getting in from under the car....(water seeks its own level.) I could see if it were dripping down from the sunroof. Thanks!
cptnsolo77
Post by cptnsolo77 »
Last time I had water in the passenger seat, the sunroof drain was blocked. There was a glob of dirt sitting right in the hole.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
RodDoe
Post by RodDoe »
I do see holes in the sunroof (guess those are for rain drain) that look obstructed with debris. I removed it..... and am keeping my fingers crossed. Thanks!
jake75
Re: (RodDoe)
Post by jake75 »
Egzachery why I am no fan of sunroofs.
RodDoe
Post by RodDoe »
Tring to snake a wire down the sunroof drain....snaked about 4 feet down. I cannot push anymore down. Where is the drain suppose to come out from the front passenger side area.
