12v Power Source Controlled By Driving Lights/Turn Signals
A Psycho Martyr
Post by A Psycho Martyr »
Ok, I know to many of you, this is common sense, but I didn't know, so I'm posting what I found out.If you are doing any accent lighting or anything electrical, you can use the turn signal wiring for a 12v power source.Here's a pic of the wiring:If you use the solid green wire, your add-on will come on with the driving lights...If you use the green w/white stripe wire, your add-on will blink with your turn signals.I know I'm not the only one who has thought of adding turn signals in the mirrors, and now I know to use the green w/white wire for my power source. Just wanted to clarify the difference in the green and green w/white wires.
DressedInBlack
Re: 12v Power Source Controlled By Driving Lights/Turn Signals (A Psycho Martyr)
Post by DressedInBlack »
Good to know. Thanks Brandon! And don't worry, I'm very pedestrian when it comes to things electrical.
http://
A Psycho Martyr
Re: 12v Power Source Controlled By Driving Lights/Turn Signals (DressedInBlack)
I was gonna wait and post before I tried wiring anything to see if anyone knew what was what, but decided to go ahead and try to get it right the 1st time ended up making my Angel Eyes blink with my turn signals.lolthat's how I found this out
joshuaeb09
Post by joshuaeb09 »
lol When I had my expedition I used some relay trickery to get my angel eyes to stay on and blink with the turn signals. Was actually pretty cool.
2009 Silver Vibe GT AutomaticI/H/E/Unichip @ 93octaneMy Garage : http://forums.genvibe.com/zerothread?id=43521" onclick="window.open(this.href);return false; - Gone (Sold)
2005 Expedition Limited 2WD|4R75W 4SPD Auto|3.73 Gears|I/E|5Star Tuned@ 91|3" Lift/Level - Current Ride
Oh the possibilities!!! Thanks Brandon! This helps a ton. Although I'm not yet sure of how it will help...
lovemyraffe
Post by lovemyraffe »
Great info! Thanks Brandon!
Blanco_Diablo
Post by Blanco_Diablo »
What is the white wire for?
Serj22
Re: 12v Power Source Controlled By Driving Lights/Turn Signals (Blanco_Diablo)
Post by Serj22 »
Thought:Two led light strips under the footwellls. One on the driver side hooked to the driver side turns, then the opposite for the passenger. Result: Blinking footwells for each side...
Pioneer HU2 x D3tAK tweeters in stock location (M&T)4 x Diamond Audio D162.5i1 x Pioneer TS-W309S4 SubPolk Audio Pa330 (To drive Sub)
A Psycho Martyr
Re: 12v Power Source Controlled By Driving Lights/Turn Signals (Serj22)
then you'd NEVER drive for miles not knowing your blinker was on.lol Good ideaand the white wire is the ground for both greens
