Moon and Tunes upgrade
NiceWubsVibe
Post by NiceWubsVibe »
I recently purchased an '04 Vibe and was looking to pick up a moon and tunes piece and maybe upgrading the sub. im guessing it would be very easy to throw in a harder-hitting 8" sub (due to the fact its the same size as the factory sub) would it be possible to modify the factory casing to house a 10"
Wolfman213
Re: Moon and Tunes upgrade (NiceWubsVibe)
Post by Wolfman213 »
The factory sub is actually a 6.5. I've placed and aftermarket 6.5 in the factory sub housing and IIRC, you could possibly fabricate it enough to fit an 8 if it's a shallow mount (very skeptical though), but I seriously doubt you'll be able to fit a 10 into the factory housing.
BlueCrush
Re: Moon and Tunes upgrade (Wolfman213)
Post by BlueCrush »
Quote, originally posted by Wolfman213 »The factory sub is actually a 6.5. I've placed and aftermarket 6.5 in the factory sub housing and IIRC, you could possibly fabricate it enough to fit an 8 if it's a shallow mount (very skeptical though), but I seriously doubt you'll be able to fit a 10 into the factory housing.Really? You did this? Got any pics? I still have my stock sub box retrofit waiting for me to finish it.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Wolfman213
I don't have any but I plan on tearing into the Vibe this weekend and will try to remember to take some.
bigdaddyjosh
Post by bigdaddyjosh »
You could always just make your own 10" sub box. You can even make it form fitting to fill the same space where that moon and tunes box would go
Pioneer AVH-P8400BH HU Polk Audio DB-6501 Components Pioneer GM-6400F Amplifier K&N drop-in filter Fiberglass Sub box w/10" Cerwin Vega
VibeBear
Re: Moon and Tunes upgrade (bigdaddyjosh)
Post by VibeBear »
Like bigdaddyjosh said, you could make your own where the factory moon & tunes would go. This is what the head installer at my work did in a first gen Matrix and what I did on the other side in my '09 Vibe 'Although I plan on building a new box on the passenger side, for a 10" sub because the 8" doesn't hit hard enough for me
1992 Chevrolet Camaro RS 305/5-speed, Bright Dark Teal
2009 Pontiac Vibe Base 1.8L/5-speed, Carbon Grey
bigdaddyjosh
Re: Moon and Tunes upgrade (VibeBear)
I made one for a 10" sub. It came out decent. I could have done a better job on the bondo before I painted it though. I can always sand it an smooth out the bondo and repaint it. I documented the whole build on the forums here. Take a look and see if it is something you would want to persue.http://forums.genvibe.com/zerothread?id=43985
