"...the best way to increase fuel efficiency is to adjust the nut holding the steering wheel. "
ponta2147
Post by ponta2147 »
http://www.cnn.com/2011/TECH/i...p_bn6I thought you all would like this article.
lovemyraffe
Re: "...the best way to increase fuel efficiency is to adjust the nut holding t ... (ponta2147)
Post by lovemyraffe »
Good read, and very true.
ramenboy...
Post by ramenboy... »
cool. the title of this thread says it all
de-badged o4 vibe
o2 triumph speed four
Try and try as I may... speeding, jackrabbit starts, stop and go city, lead foot, heavy winter tires and towing (and all combined into one)... I find it nearly impossible to get worse then 30mpg!That being said, I can also coax 40mpg out of it if I try!!!So I've adjusted myself to: I paid for the gas, it's mine! I'll burn it however I see fit! At least gas is cheap!
Old Tele man
Post by Old Tele man »
...if the "steering wheel nut" doesn't want to save fuel, they won't....if the "steering wheel nut" does want to save fuel, they will!
...and the Devil said: "...yes, but it's a DRY heat!"
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
