Nice antenna mast but it's still too long to fit under my cargo basket. Fortunately, I don't need the mast at all since the reception is excellent for the stations I listen to.But, what I'd like is something to protect the hole, especially when I need to install the basket during winter. I would not want salt to get in...
Quote, originally posted by Jeremy96gase »The Honda S2000 antenna was too short for my taste.Too short? IMO it's just the right length. Short enough to look much better then the 19" factory one, but long enough to still get great reception. Quote, originally posted by tpollauf »Like Carrie did to her Vibe, the Honda is a perfect fit on the Vibe When are you and Corey getting Honda antennas for your Vibes ?
Quote, originally posted by J_TO_ENVY »When are you and Corey getting Honda antennas for your Vibes ?Actually I did way back sometime over the winter. Just forgot to let all my fellow Genvibers know about it. Thanks to the tip from you Carrie
Quote, originally posted by J_TO_ENVY »Too short? IMO it's just the right length. Short enough to look much better then the 19" factory one, but long enough to still get great reception. Guess I should have qualified my response a bit better. At the time I was listening to AM radio, and the S2000 antenna was too small to get good reception. FM signal was the same to slightly worse. I did like the look of it though.
Quote, originally posted by tpollauf »Actually I did way back sometime over the winter. Just forgot to let all my fellow Genvibers know about it. Thanks to the tip from you Carrie Nice! Looks great Tim !Quote, originally posted by Jeremy96gase »Guess I should have qualified my response a bit better. At the time I was listening to AM radio, and the S2000 antenna was too small to get good reception. FM signal was the same to slightly worse. I did like the look of it though.Got cha . I hardly ever listen to FM, let alone AM. 99% of the time I listen to XM or CDs.
