Washer fluid wipers
Pujon
Washer fluid wipers
Post by Pujon »
I have recently noticed that even though i have fluid in there, the spray is not very much if any at all. I looked to make sure the hose wasn't kinked from the bottle to the wipers. It also seems to be both on the front and the rear wipers. last week I put nearly half a bottle of fluid in there and it seemed to be fine, but this week I have used it and I get one decent squirt and then it goes down from there. Any suggestions?
ramenboy...
Post by ramenboy... »
maybe try checking the nozzles.you can use a safety pin and make sure they're not plugged by road grime, etc.
de-badged o4 vibe
o2 triumph speed four
Pujon
Post by Pujon »
I used the a paper clip on the nozzles, but there was no change. Any other suggestions?
MotoAce51
Re: (Pujon)
Post by MotoAce51 »
My mom's had one of the washer fluid pumps go bad. The rear washer would work but not the front. He checked the lines by swapping the hoses and seeing if fluid would run. Its simple to check the pump. You can get at it from the front wheel well.
2004 Vibe Base- Injen CAI, 10,000K HID's, Projector Retrofit W/ Angel Eyes, Billet Grilles, Kicker KX6.5 Components, Helix TB Spacer, Pioneer Premier HU
Pujon
Post by Pujon »
I'll have to check that. I can hear a motor running when I try to spray the windows that could be the wiper motor though
MotoAce51
Re: (Pujon)
Post by MotoAce51 »
The pump could still be running but broken but I don't think it would do it to both the front and rear at the same time. Usually only one would go out at a time. But check it anyways. I can't remember the specifics on our when we fixed it but it was def the pump.
Pujon
Post by Pujon »
I poured a bottle of water in there last night and it sprayed out of the front right away. I dind't try the back. wonder if i just got bad fluid or something
Wolfman213
Post by Wolfman213 »
Bad fluid is always a possibility. I went with a cheap Kmart brand one time bc I needed fluid bad and it ended up being a waste with very low pressure. I ran the pumps in like 15 second burst sproatically throughout the day in order to expell it as quick as possible without burning up the motors.
ou.grizzly
Post by ou.grizzly »
Maybe it was ran low, sediment in the line, and clogged the nozzle?
