I am a new owner of a used 2006 base model FWD Vibe with 52K miles. The car is is good condition and I purchased from the previous adult owner in June of 2010. The car had newish Fusion stock size, properly inflated 205/55/16 tires on OE steel wheels. All four tires showed cupping on the inside edges and the vehicle made excessive road noise. I cross rotated all four wheels to reverse rolling direction and the noise reduced to a more moderated level.After a rain a couple of weeks ago I was able to see the dried tire foot prints of all wheels on my garage floor. The impact was very dramatic. All four wheels clearly showed what appeared to be excessive negative camber. I took the car to a trusted alignment shop in Boulder, CO and the alignment readings were within spec except for the RF toe.The Primary angle specs. in decimal degrees.FRONT Left Right Actual Spec Actual Spec Caster 2.91 2.03 to 3.53 2.84 2.03 to 3.53Camber -0.70 -1.32 to 0.18 -0.77 -1.32 to 0.18Toe 0.03 -0.10 to 0.10 -0.12 -0.10 to 0.10REARCamber -1.21 -2.20 to -0.70 -1.79 -2.20 to -0.70 Toe 0.13 0.00 to 0.26 0.02 0.00 to 0.26 Given my tire wear issues I had the shop install camber bolts in the front to correct the negative camber as close to zero degrees as possible. The camber bolts allowed the front camber to be adjusted to:Left Front -0.19Right Front -0.17In addition they adjusted the toe into spec.Right 0.01Left 0.01I was unable to have the rear camber and toe adjusted at the shop because they wouldn't be able to get the shims until the next day. I purchased and installed the shims the next day. By my calculations my rear camber and toe should now be Left RightCamber -0.71 -0.68Toe 0.12 0.14The car now drives much more quiet than it did before. Time will tell if tire wear improves. I used Specialty Products camber bolts and 75800 shims.The attached pics of my car's foot print on my garage floor were my clue that something needed to be done. A vehicle that is tracking on only 1/3 of the tire foot print can't be safe or kind to your tires.I'll attach the other three tire foot prints in additional posts
