Suspension question
pperrone
Suspension question
Post by pperrone »
Has anyone had problems with the front tires rubbing holes in the wheel wells?
Pete'05 Stock Salsa
bodhi_tree777
Re: Suspension question (pperrone)
Post by bodhi_tree777 »
Is your car lowered? What size wheels/tires are you running? Maybe a dumb question, but are you sure that the rubbing isn't cause by a fastener on the wheel well lining breaking (thereby allowing the liner to sag down onto the tire)?
lovemyraffe
Post by lovemyraffe »
Unless you are running a really big wheel and have it lowered, you shouldn't have any rubbing issues except for what bhodi described.
MotoAce51
Post by MotoAce51 »
One of mine shows that it had rubbed at one point but I havent noticed anything typically.
2004 Vibe Base- Injen CAI, 10,000K HID's, Projector Retrofit W/ Angel Eyes, Billet Grilles, Kicker KX6.5 Components, Helix TB Spacer, Pioneer Premier HU
pperrone
Post by pperrone »
I have stock wheels and stock size tires. The wholes are in front of the tires. A rubbing sound occured this past weekend while driving on US 1 in the Florida keys on a particulare bumpy section. I have noticed it before then occasionally on an interstate hitting a bridge at highway speeds. I was wondering if I need to get the struts replaced. Other than the sound and the occassional rubbing, the ride is very smooth.
Pete'05 Stock Salsa
Re: (pperrone)
Check to see if the plastic wheel well has come loose or been bent.
SeattleJeremy
Post by SeattleJeremy »
How many miles on the car? Have the struts ever been replaced? Have you done the bounce test? http://www.youtube.com/watch?v=bQ33n_jnaGQ
pperrone
Post by pperrone »
There are 90k miles. I do not believe the struts have ever been replaced. I was thinking it might be time for that.
Pete'05 Stock Salsa
Bedlam
Post by Bedlam »
I doubt it is your suspension. I had a similar issue with mine and the wheel well had come unsecured partially. Needed 2 more plastic rivets and for it to be clicked back into place. Looked fine just glancing at it so it was hard to tell. A solid gust of wind at speed would jar it enough to scrub the tire for a sec periodically.
07 1ZZ 5spd Stealth - Sold
03 1ZZ 6spd Shadow w/NAV - For Sale
06 AWD Stealth - Current
07 Magnum SRT-8 - Current
moonstonemike
Post by moonstonemike »
I had the same thing on my drivers side. One clip was missing inside the wheel well and when on the highway the wind would push it enough to rub the tire but when you stop and checked, everything looked fine except the hole.
pperrone
Post by pperrone »
I will check the clips on the wheel wells. Sounds logical, but it happens when I hit a bump in the road. I am going to look into new struts, after tires though. Oh and brakes.
Pete'05 Stock Salsa
