Quote, originally posted by yuppicide »Girlfriend has 2008 Pontiac Vibe. 73,000 miles on it roughly.my 04 is about the same milage.Quote »He told me the power steering fluid needed flushing? I declined. Is that true?haven't had to change mine yet. still looks good. then again, as jake is questioning i thought 05 and up were all drive by wire.Quote »Power Steering fluid wouldn't have anything to do with a car running a little differently than normally does at idle, right?shouldn't. while reading this it is technically possible
http://auto.howstuffworks.com/steering4.htm cause the pump is dependent on the engine.Quote »Now while I was there he said some gasket was only hand tightened, probably whoever did my last oil change. He said if that came off my engine could have blown up.also going off what jake said, if the mechanic was calling the filter the gasket, it should only be hand tightened. well, a little past, but not heavily torqued on at all. i just changed my oil yesterday, tightened on the filter by hand. always have.Quote »So anyway, my girlfriend says since oil change the following:The pedal vibrates a little and sometimes makes a different noise when idling or going to park than the car normally would.since you said the air filter was changed: how dirty was the old one that was replaced? cause if it was really bad and now it's good, the engine/computer might be relearning based on the new higher airflow. when i put in my CAI i remember my car sounding really different. once it learned the higher airflow sometimes at idle i notice it drop lower than what it used to which for me causes some rattle. really weird. only at 700RPM though, guess that is the car's resonance.     if i put the car into Neutral, rpms go up, rattle goes away for me.Quote »I'm heading to Niagara Falls this weekend.. it's a 7 hour drive. I am off all day on Friday and we're due to leave at 4pm.Do you think a tune up is something I should look into?What might I expect to pay for a tune up and what kind of parts?um... only thing i would possibly do also would be a radiator drain and fill depending on when it was last done. also, when were the brakes last checked/changed?
None. Vibe is gone.
