Poor AM/FM reception (aftermarket) '09
dayday
Post by dayday »
So far I've had a Clarion and a JVC, and now I'm getting ready to put in a Pioneer. I've had poor reception with both and I'm wondering if this is common with aftermarket headunits or if maybe I have a bad antenna adapter. I did run the ground through the factory harness and also added one to the ground point just below the headunit. Anyone else experience poor AM/FM reception with aftermarket headunits in '09+ Vibes?
'09 Vibe 2.4L 5sp
Beer Belly
Post by Beer Belly »
FM works great, but i've never been able to get even 1 AM channel....not sure why either.
KNINE
Re: (Beer Belly)
Post by KNINE »
I have the same problem, but I never listen to am. I think I once read a post about this stating that the am antenna is powered, and needs 12 volts on some lead someplace. Hopefully somebody more knowledgeable than me can give you a better answer.
"Don't look to the government to solve your problems, the government is the problem." Ronald Reagan"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." Ben Franklin.
dayday
Post by dayday »
My FM channels seem about 1/2 as strong as they were with a stock headunit, even the strong stations will get some static periodically. AM is very week, fades in and out and the volume usually needs to be increased by nearly 25% to hear anything. I like to listen to the news on my way into work. The local news channel has an AM and FM version, both suck:(
'09 Vibe 2.4L 5sp
KNINE
Re: (dayday)
Post by KNINE »
My FM seems okay. I mostly listen to Sirius so it's not an issue for me.
audiovibe
Post by audiovibe »
double check to make sure the Tan power antenna lead is hooked up to a source that gives +12 volts. If that does not work you could always get an aftermarket powered antenna.
dayday
Re: (audiovibe)
Post by dayday »
Hmmmm, I don't think I used the tan for anything. I thought it was only used to activate a power antenna mast if the car was equipt. So it needs 12v in? Again I thought it was used to send 12v out to a power antenna mast.EDIT****OK, I'm finding some info now on previous year Matrix/Vibe that the factory antenna is amplified. I assume now the newer generation Vibes are also. The "tan" wire you mention I assume is in the car's factory harness somewhere and I should use the Blue/White wire from the aftermarket headunit to power that?
'09 Vibe 2.4L 5sp
lowincash
Post by lowincash »
I don't listen to AM stations but the FM reception is not as good as with the stock radio it seems. I have a kenwood unit. It varies tho, it's weird because while at a stop light it'll sound normal then if I move forward a foot or so then the reception will get static and stuff lol
-- 2009 Vibe GT in Jet Black
audiovibe
Re: (dayday)
Post by audiovibe »
Quote, originally posted by dayday »EDIT****OK, I'm finding some info now on previous year Matrix/Vibe that the factory antenna is amplified. I assume now the newer generation Vibes are also. The "tan" wire you mention I assume is in the car's factory harness somewhere and I should use the Blue/White wire from the aftermarket headunit to power that?Yes the Tan wire is in the factory harness, hook that up to the blue/white frim the radio and you should be golden.
dayday
Re: (audiovibe)
Post by dayday »
BINGO..... Tan wire did the trick!!!!1,000,000 thanks to you......and there was even a taped up unused blue wire in my Metra harness that matched up to the tan wire's pin, DOH!!!
'09 Vibe 2.4L 5sp
audiovibe
Post by audiovibe »
Happy to hear it helped you out:)
RobK
Re: (dayday)
Post by RobK »
i have an 03 vibe with the same problem with my pioneer headunit...is there a tan wire with mine? I don't recall there being one...
dayday
Re: (RobK)
Post by dayday »
When searching for the info here that I needed, most if not all posts pertained to the earlier vibes. There were posts saying the wire needed was attached or ran along with the antenna behind the radio.
'09 Vibe 2.4L 5sp
