So I've gotten my next project. it's my sister's 1999 Pontiac Firebird. The only bad thing is she's using my Vibe til I'm done with this...Has multiple problems needing to be fixed:misfire in #1 cylindersecurity issuedoor sensors causing alarm to go off when lockedbrakes: turned and bledweather strippingcleaned outspeakers
Got the misfire fixed. had a random misfire in cyl. 6, turned out to be a bad plug wire and ignition module. replaced the ignition coil too for safe measure as i already had a new one.This is what i had to do to get to the dang plugs...
