Mysterious engine noises
So, recently my dad and I changed the oil and automatic transaxle fluid in my 2006 Vibe. I checked the levels again to the engine oil (which was at the proper level) and the transaxle fluid (which was between the two "hot" divots 30 minutes after I'd been driving), following the instructions in the manual.I don't really know if that first paragraph is really relevant or not, as I don't know much about cars besides sometimes things happen and they cost a lot to repair. Anyway, sometimes I hear a low whining noise emanating from my engine at various speeds (although not while I'm idling). It sounds kind of hydraulic in nature--similar to http://www.youtube.com/watch?v=OOR2cTu_QZ4 but at a higher pitch and a lower volume...uh, you might want to turn your volume down for that video. The pitch remains constant and then stops after a couple of seconds, and the volume tapers off in a similar manner to the noise in the video that I linked to, but the amount of time between the occurrences of the sound is much greater. It's really inconsistent on intervals, but only occurs when the car is moving.I think it's been making this noise for about a week, and I can feel the vibration from it through the gas pedal. My dad is stumped, but said it's probably nothing serious, and that if I took it in to have investigated, it would probably cost $300 just for that...Other information that might be useful:-The temperature for this entire week has been over 100 degrees F-The car has about 69k miles on it-I haven't tried driving with the AC off...I guess I should do that tomorrow morning
Re: Mysterious engine noises
The noise has greatly decreased in volume and frequency. Earlier today it was loud for a second after I went over a bump roughly, but I haven't heard it since.I'm not too worried about it now, but if anybody knows anything about it, go ahead and say something. It was a really bizarre sound that had me pretty stressed out whenever I heard it.
keithvibe
Re: Mysterious engine noises (lannvouivre)
Post by keithvibe »
what transmission fluid did you use?The wrong fluid will cause the noise you are describing
Re: Mysterious engine noises (keithvibe)
Dad's pretty sure we got the "T-IV Automatic Transmission Fluid," but we threw the bottle away. We're going to Wal*Mart to double-check ASAP.
sideshowalan
Post by sideshowalan »
Does the sound change with vehicle speed, RPMs, shifting? If you have the right fluid it may be unrelated.Possibly a wheel bearing, next time it shows up, try swerving left and right to shift the wegiht around. If it's louder one way and quieter the other, it's a bearing.
2008 Pontiac Vibe
2008 Toyota Sienna XLE
Re: (sideshowalan)
http://www.castrol.com/castrol...28224 That's the transmission fluid we used and it says it's recommended for T-IV, so I think it should be fine.Quote, originally posted by sideshowalan »Possibly a wheel bearing, next time it shows up, try swerving left and right to shift the weight around. If it's louder one way and quieter the other, it's a bearing.I'll do that if it happens again (and I'm not surrounded by other motorists), but it's been really quiet.
MotoAce51
Post by MotoAce51 »
Is there a TB spacer on the motor?
2004 Vibe Base- Injen CAI, 10,000K HID's, Projector Retrofit W/ Angel Eyes, Billet Grilles, Kicker KX6.5 Components, Helix TB Spacer, Pioneer Premier HU
Re: (MotoAce51)
Quote, originally posted by MotoAce51 »Is there a TB spacer on the motor?I don't know; do you mind me asking how to check? The internet search isn't being helpful tonight.If it helps, my Vibe hasn't gotten any modifications from when I bought it used, and its only other owner was a rental place.
Zvibe04
Post by Zvibe04 »
it probably dont have a spacer then, ive noticed the same thing, only happens when i use my ac(which is very rarely), i think its the compressor, bc its done that ever since my dad bought it brand new from the dealer in 04
2004 base vibemoon and tunes pakagealuminum rimsauto trans (hated)this car is my BABY
