A/C Blower works eratically, in all speeds
nolaloha
Post by nolaloha »
The A/C Heater Blower is working unreliably. The blower usually will not start after the engine has been turned on. Trying all the blower speeds, vent open or shut, A/C on, heater on does not result in the blower working. Then usually,after a few minutes or hours, the blower will come on. Sometimes after a bump in the road, sometimes not. when it does come on, it works in all speeds, and can be turned off for a minute, and turned on again. The blower sounds smooth in all speeds, and once running, will keep running. Can you suggest some trouble shooting? Resistor? Fuse? Relay block? Blower motor?
DressedInBlack
Re: A/C Blower works eratically, in all speeds (nolaloha)
Post by DressedInBlack »
I im'ed you these but I will put them here for reference. http://forums.genvibe.com/zerothread?id=36099 http://forums.genvibe.com/zerothread?id=44248 Best of luck!
http://
