2009 GT Monsoon ID3 and Radio Text no longer displaying
viewwin
Post by viewwin »
Two days ago, the ID3 tags and radio text will no longer display on the main home screen on the factory radio. I can still bring it up with the display button, but info is no longer display while on the main screen. Has anyone else had this problem?
09vGT
Re: 2009 GT Monsoon ID3 and Radio Text no longer displaying (viewwin)
Post by 09vGT »
Sometimes the autotext feature will turn itself off. I keep my off for this reason. But, click menu, then you should see autotext, click it, then click on. Or somewhere around the lines of that. You should be able to find it really easy.
viewwin
Re: 2009 GT Monsoon ID3 and Radio Text no longer displaying (09vGT)
Post by viewwin »
Quote, originally posted by 09vGT »Sometimes the autotext feature will turn itself off. I keep my off for this reason. But, click menu, then you should see autotext, click it, then click on. Or somewhere around the lines of that. You should be able to find it really easy. I checked, the autotext is on. I turned it off then back on and still no text unless I press info
