Outside Temperature Indicator
OlDood
Post by OlDood »
Yesterday just after noon, the outside temp indicator on my GT showed 112 degrees f.! That prompted me to wonder: (a) where the sensor probe is located. If it is under the hood somewhere, it could be influenced by the engine bay temp, and (b) if I had a malfunctioning indicator.The notion of a malfunction was laid to rest this morning, when the newspaper reported that the temp in Riverside yesterday was _112_, validating the accuracy of the in-dash indicator.I'm still curious, though, where the probe is located. Anyone know?
[Modified by OlDood, 2:53 PM 9/2/2002]
VibeOn!Ray Fincher OlDood
rasermon
Re: Outside Temperature Indicator (OlDood)
Post by rasermon »
I'm still curious, though, where the probe is located. Anyone know? It's in front of the radiator. You can see it through the lower front grill.
Campbell
Re: Outside Temperature Indicator (rasermon)
Post by Campbell »
I can see the horn in front of my radiator and nothing else with wires. Now I'm curious.
Silver Base Vibe with Nav System that I wish had an OBD-II link
NovaResource
Re: Outside Temperature Indicator (Campbell)
Post by NovaResource »
It's at the bottom, center of the radiator under the hood latch.
NSimkins
Global Moderator
Re: Outside Temperature Indicator (NovaResource)
Post by NSimkins »
If you look through the grill in this area you will see it there:
[Modified by NSimkins, 4:13 PM 9/9/2002]
rasermon
Post by rasermon »
Frosty
Post by Frosty »
I haven't had my car for two weeks yet so I am still testing out some of the features.One feature that works that I was not too happy to see was the "-" sign before the temperature today. It was -1 Celcius on the dash when I got in the car, had to scrape the windows, use the defrosters, yuck.Then I got to work and it was -4 Celcius, the car was warm so that was another feature I haven't tested too much that worked out ok.I am ready for winter though, got my Canada Tire Icetracs in the hatch!
Frosty 5 speed Vibe Power & Safety Packages. Naturally Aspirated my gallery
NSimkins
Global Moderator
Re: Outside Temperature Indicator (Frosty)
Post by NSimkins »
I had my Outside Temperature Gauge up to 104 degrees F during the summer here. I will see this winter how cold it gets and what my readout states.
Mr. Poopypants
Post by Mr. Poopypants »
Just curious, Does anyone know how you can change the display from farenheit to celsius?
NovaResource
Re: Outside Temperature Indicator (MFFenton)
Yes, drive to Canada, trade in your Vibe and buy a Canadian Vibe. US Vibes are in Fahrenheit while Canadians are in Celsius.I don't think there is a way to change it without changing the display or the "brain".Also see this thread:http://forums.genvibe.com/zerothread?id=2006I was looking as some pictures and I noticed that the "C" for Celsius is in the top half of the temp number while the "F" for Fahrenheit is in the lower half. I would assume this means the display is the same for both American and Canadian Vibes.
