I found this, and figure it would work on the Vibes. It might be a good deal. Just sdeeing what you all think about ithttp://www.performancepartz.co...=1536
Quote, originally posted by GT_03 »I found a old article off a Honda forum, and it says it is "plug-n-play" it tunes itself. Gains were from 8-12 hp. sounds kinda good Well its not bad if its true considering a $220 Injen CAI gave about 10hp. So it would be about the same. This is something to look at I wonder if it tunes itself or will it know it has a CAI and exhaust maybe gains will be more than what it says?
2006 Pontiac G6 GTP3.9L V-6 240hp and 241 lb-ft or torque18" Aluminum, five-spoke, flangeless200 Watt, 8 speaker Monsoon sysChrome dual exhaust tipsLiquid Silver MetallicBorla Custom ExhaustDr. Speed Cold Air Intake
My Car, with the kit on. it looks awesome! come and check it out, tell me what u think.P.S. the gray will be painted momentarily http://www.cardomain.com/ride/514882/1
well, JET chips are usually the ones you have to send them your ECU and they add their chip and reprogram. the gains and torque are minimal and you spend much more money. then if you do any mods, you have to send it back in for reprogramming. i know several people who have one and they really dislike it due to the complications of having to send it in. the only reasons i got the unichip was because it came highly recommended and that the reported gains were more or less in the 20's for hp but the low end torque was like 25!
My opinion is, it's not gonna work. the stock ecu will just defunk it and calibrate all settings to stock. that's why the UNICHIP took so much time and tuning. The toyota ecu is smart little fella!
Jet V-force Plus is a piece of JUNK! I had one on my 2005 Matrix...almost lost every sensor when the damned thing shorted out internally. Jet would not do anything about it. I am looking into a suit against them.
This is JUNK! I had it on my Matrix and it FRIED after 3 weeks. Jet will not take it back leaving me stuck with $250 piece of plastic JUNK! DO NOT BUY!
