I have non-premium 4 speaker stereo and wanted to get a component set. Any ideas on where to mount them? The side curtain airbags kinda mess with my original plan.
Quote, originally posted by papacueball »No problem, Tx. The sail panel basically covers the bolts and wiring for the side view mirrors. Should be plenty of room behind them, too.Oh cool, that's where I was hoping you were talking about. I think they would go good there.
Hey I have a non monsoon system and had my tweets installed professionally in the door. Here is where they did the install. Pay no attn. to the messy black surround. The installers did a crappy job and the speaker fell out several times. So I used some special glue that should keep that from happening again. I just need to cut off the excess.
Pioneer AVH-P8400BH HU Polk Audio DB-6501 Components Pioneer GM-6400F Amplifier K&N drop-in filter Fiberglass Sub box w/10" Cerwin Vega
Quote, originally posted by ponta2147 »Well, I know the tweeters in the Monsoon sound system are in that exact spot:I wonder if I could put them in the door panels right below the sail panel.
Quote, originally posted by bigdaddyjosh »Hey I have a non monsoon system and had my tweets installed professionally in the door. Here is where they did the install. Pay no attn. to the messy black surround. The installers did a crappy job and the speaker fell out several times. So I used some special glue that should keep that from happening again. I just need to cut off the excess.Don't relly want them that low in the door, but thanks for the suggestion.
just fyi. Most auto sound manufacturers and installers recommend placing the tweeter and mid no more than a foot apart from each other due to some issue with timing. Sound travels at a certain speed and if the tweets are installed 2 feet from your ears and mids being 4-6 feet from your ears then the sound arrives at your ears at 2 different times.This may be very minute and un-hearable but this is just fyi.
Might be a good idea to get some adhesive backed velcro and try them in all the different locations. Once you cut a hole in the door panel, you're committed.
How big are your tweets? Mine are 1" and with the cups they sit in 1.5"the installer down here recommended not putting them in the sail panel because the panels have a slight curve in them and he wouldnt be able to make them sit flush. It could be done, I think... But you would have to figure out a better way to mount without the cups.Im truly interested to see how it all comes out.
Quote, originally posted by Sublimewind »Do they have a surface mount? Most have some sort of a slightly aim-able rotating cup to surface mount.. rather than flush mount.. Haven't bought any yet, but my goal is flush mount. May not be possible but will try that avenue first. Even if it means buying them separately.
