Quote, originally posted by Bad Vibe »just came up with this terrible idea, it will ruin my life and possibly bankrupt me but i really want to do it.I tryed towing with my vibe gt and it got wack mileage like barely 20mpg from ny to dc which defeats the point of 4cyl fuel efficient towing my gto would have done better.so i started considering getting a tdi VW jetta/ passat wagon or golf hatch for the torque and mpg, but id give up my toyota reliability aside from the longevity inherent to diesels the rest of the mexican built duetchbag mobile may just fall apartthen it came to me, in England they offer a bunch of diesels for toyota the hottest being the 2.2l 2AD-FHV found in the IS220d, the avensis(sedan platform from which the tC springs) the corolla and corolla hatch variants which are somewhere between a yaris and a matrixthis motor is 177hp 295 lb ft tq stock and a chip (under $500) brings it up to 230hp 358lb ft itll do plenty of towing and around 50mpg i believeany thoughts on difficulties from import to the swap itself i plan to get a full corolla front clip and fuel tank to minimize difficulties w/ swap partsplus ill have a spare 2zz for mr2 swappingengine info:
http://en.wikipedia.org/wiki/Toyota_AD_ ... ..y.htmyou gotta remember that the diesel over there is different than ours. there is no way in hale that you can get 50 mph on our diesel over here. The motor would probably catch the flue over here. The 2zz is has no torque. the end. no wonder you cant tow anything. Put in your spyder and then you will have a poor man's lotus elise. (removed), you could turbo your 2zz. And as we all know, turbos are torque multipliers... for sure. Now , I know , I know, that issss expensive. But, ttt I know a secret abut the 2zz. You can turbo it up to 5 psi without doing anything for fuel management...no lie. I have inside information on this. And, I have driven one like that . After that , it is hard as hale to tune it. , but if you are not greedy you can boost up to 5 psi, no questions asked. if you 2zz the spyder...put a turbo on there , put one on that doesnt spool up until 4k, that way you will be in open loop and you will have no detonation issues and still be abel to boost up to8k rpms and make 18o ft #'s of torque.....without any extra fuel management. I am sorry , I am jaded. I am all about turbos. ....never mind..go find your diesel torque monster from the land of royal weddings.
pics 10/2/05
http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
