I have an '03 vibe with 145K on it that just started making a ticking noise in the engine. I've replaced the rod bearings and hooked up a mechanical oil gauge. I was suprised at how high my oil pressure was (60psi) at a cold idle. At warm idle - 30psi and warm engine at 2K - 60psi. Are these readings normal? Thanks for any input!!!Jason
I just had same problem and the ticking sound is a crack in the fly wheel... i got it fixed about 2 months ago and just recentley it started making that noise again...
